ccgi white-label hosting - control panel is blank - no tools, no settings
disfroot
Back in 2014 when CGI hosting was migrated to white label at https://hosting.plus.net/portal/# I got my login credentials and everything looked fine.
It's now 2017 and I log in again only to find that all the apps/tools are gone ( see screen grab)
I can only assume that, even though I met the migration criteria in 2014 ( I got sent an e-mail with the new white-label login), my slight use of the service has caused someone to try to whip the features away from under my nose, even though I now have a use for them.
How do I get it back ?
4 REPLIES 4
Chris
Legend
Fixes: 169
Re: ccgi white-label hosting - control panel is blank - no tools, no settings
Can you check it now please?
disfroot
@Chris
thanks for looking at this !
is this right ? all the tools that should be there are there ? (2 screengrabs attached)
spraxyt
Aspiring Legend
Fixes: 75
Yes, all the tools you should have are there. Once you've used any of them they will be shown as "Recently used" on the opening screen.
David
disfroot
@spraxyt
triffic, will mark as fixed, thanks @Chris
