ccgi webspace problems
- Everything else
- ccgi webspace problems
25-03-2008 8:57 AM
I'm trying to get a Textpattern CMS site working on my webspace http://ccgi.weebleville.plus.com/erme
The first issue is that I can't get the pictures to display, they just come up with red crosses. They are in a folder called images within the above site, but won't even display if you paste the absolute path into a browser? However, they do work if I remove the .htaccess file (which is meant to be there).
The other issue is that Textpattern is telling me to turn register globals off, which I did in the .htaccess file, but to no avail. The helpdesk said that it is a server die setting and they need to do it?
I've used Textpattern for a while with three other hosting provides and never had an issue until I tried to I'd my ccgi webspace.
Thanks for the help in advance!
Message 1 of 3
(882 Views)
2 REPLIES 2
Re: ccgi webspace problems
25-03-2008 9:29 AM
PlusNets CCGI webspace has been made very secure meaning a lot of things will not work 'out of the box' as a result.
You can't change register_globals in .htaccess along with a lot of other server side php parameters due to the security and also due to the fact the PlusNet run PHP in cgi mode meaning .htaccess is ignored when running a php file.
Posting what you have in .htaccess would help.
PlusNet use *nix based hosting meaning paths are case sensitive ulike a lot of other hosting which uses WIndows and is not case sensitive. So make sure you always use lower case for file and directory names.
Message 2 of 3
(196 Views)
25-03-2008 10:55 AM
Thanks Peter - here's the htaccess contents.
.htaccess file contents:
#DirectoryIndex index.php index.html
#Options +FollowSymLinks
#Options -Indexes
<IfModule mod_rewrite.c>
RewriteEngine On
#RewriteBase /relative/web/path/
RewriteCond %{REQUEST_FILENAME} -f [OR]
RewriteCond %{REQUEST_FILENAME} -d
RewriteRule ^(.+) - [PT,L]
RewriteRule ^(.*) index.php
</IfModule>
#php_value register_globals 0
#Options -Indexes
RewriteEngine On
</IfModule>
Message 3 of 3
(196 Views)
- Everything else
