ccgi timeout errors - ccgi server 3
Tony_W
I'm getting some intermittent time-out errors on PHP files located on the ccgi server.
Running the clock times  program ( http://ccgi.csogilvie.plus.com/dates.php ) has given:
I am running on: ccgi03.plus.net
Mon May  4 18:16:20 UTC 2009
Mon May  4 18:16:22 UTC 2009
500 read timeout
sh: line 1: ssh: command not found
So it looks like something might be up with ccgi server number 4 (ccgi04.plus.net)
A second run gives:
I am running on: ccgi01.plus.net
Mon May  4 18:23:13 UTC 2009
Mon May  4 18:23:14 UTC 2009
500 read timeout
so it seems it might be consistent.
I will ring support.
15 REPLIES 15
Tony_W
Re: ccgi timeout errors - ccgi server 4
Support took it on board and I think it is now fixed.
I have tried the clock script 5 times, spaced 3 minutes apart and have not had a problem.
Tony
zubel
I was having intermittent problems earlier whilst trying to sort out my sisters website.  I thought it may have been related to Rumpus, but seems like it may have been one of the CCGI cluster, as per this thread.
B.
bobpullen
Fixes: 288
The servers were given a kick earlier this morning in response to an internally raised problem. Should be OK now but shout up if you continue to experience problems.
Tony_W
Anyone else getting timeout errors on ccgi?
The 'clock-reading' script is giving:
I am running on: ccgi04.plus.net
Mon May 11 18:02:28 UTC 2009
500 Can't connect to 212.159.7.150:80 (connect: timeout)
500 Can't connect to 212.159.7.155:80 (connect: timeout)
Mon May 11 18:02:49 UTC 2009
I will put in a support ticket. [Edit] Have done the ticket.
[Edit] Now seems to be 1, 2 and 3
500 read timeout
500 Can't connect to 212.159.7.150:80 (connect: No route to host)
500 Can't connect to 212.159.7.155:80 (connect: No route to host)
Mon May 11 18:40:32 UTC 2009
Tony
Tony_W
Re: ccgi timeout errors - ccgi servers 2 and 3
Tue May 12 12:12:19 UTC 2009
Tue May 12 12:12:29 UTC 2009
Server 2 down. CS not aware of any maintenance
Tony_W
Fingers crossed - all servers running with the correct time!
Tony_W
Its happening again - servers 2 and 3
Tue May 12 17:55:47 UTC 2009
500 read timeout
Tue May 12 17:56:10 UTC 2009
Tony
spraxyt
Aspiring Legend
Fixes: 75
And for me:
Tue May 12 18:14:40 UTC 2009
Tue May 12 18:14:54 UTC 2009
5 min later:
Tue May 12 18:19:24 UTC 2009
Tue May 12 19:19:26 UTC 2009
Tue May 12 18:19:29 UTC 2009
David
David
spraxyt
Aspiring Legend
Fixes: 75
A Service Status has been issued
CGI Website Accessibility (56448) - NEW
CGI Services
Posted on: Tuesday 12 May 2009, 19:17
Our engineers are currently investigating issues with access to customers' CGI-hosted sites. Any websites hosted on our CGI servers, may be experiencing slowdowns or timing out.
We're working to restore service as quickly as we can, and will post another update as soon as we have further information.
Kind Regards,
Customer Support
David
Tony_W
Server 2 is back up now, but its clock is wrong AGAIN!!!!!
Tony_W
Server 4?
Wed May 13 20:52:09 UTC 2009
Wed May 13 20:52:10 UTC 2009
500 read timeout
They "are aware of it and the Networks team have been called"
Tony_W
Fixed - and the clock is correct.
Well done Networks - thank you for the rapid response.
Tony_W
Re: ccgi timeout errors - ccgi server 3
Wed Jul  1 06:39:57 UTC 2009
Wed Jul  1 06:39:59 UTC 2009
Wed Jul  1 06:40:17 UTC 2009
Wed Jul  1 06:45:59 UTC 2009
500 read timeout
Wed Jul  1 06:46:18 UTC 2009
Wed Jul  1 06:52:01 UTC 2009
500 read timeout
Wed Jul  1 06:52:12 UTC 2009
All 'green' on the service status pages.
Tony
Edit - Customer services not aware of any problems...
Tony_W
The last 2 accesses have shown that the timeout problem might have been fixed.
Will try again later.
Tony
