ccgi server down 8.45pm 22nd January - [Resolved]
- Everything else
- Re: ccgi server down 8.45pm 22nd January
22-01-2010 8:51 PM
I can't get http access to the ccgi server and it appears to be down even to http://downforeveryoneorjustme.com/
FTP access works.
Anyone else seeing a problem?
Tony
FTP access works.
Tony
Message 1 of 8
(1,285 Views)
7 REPLIES 7
What's happening with CGI?
22-01-2010 8:56 PM
When I check the Help Assistant page for CGI it tells me "There is a current service issue with CGI Services. Check Service Status for info." But the service status page hasn't been updated since 30/12 and the last update doesn't tell me much about what's going on.
So, anyone know what's wrong with CGI and when will I be able to access my blog again?
Thanks,
David
Thanks,
David
Message 2 of 8
(523 Views)
22-01-2010 8:57 PM
Quote from: Tony I can't get http access to the ccgi server and it appears to be down even to http://downforeveryoneorjustme.com/
FTP access works.
Tony
Yep. Same here.
Tom.
Message 3 of 8
(523 Views)
22-01-2010 9:01 PM
Spoke to a support operative who did not know about it.
After being on hold for a further 6 minutes he came back and said that a notification had gone out that the servers are down and 'networks' have been called. He said it should be back up 'in a few minutes'.
Personally I doubt the time scale, and they will probably not set the clocks correctly when they reboot.
Ah well....
Ah well....
Message 4 of 8
(523 Views)
22-01-2010 9:09 PM
Ah, at least it's a new (hopefully short-term) thing. I thought maybe it had been down since 30/12 and I had only just noticed
Message 5 of 8
(523 Views)
22-01-2010 9:36 PM
Yay - back up again.
Tom.
Tom.
Message 6 of 8
(523 Views)
22-01-2010 9:39 PM
Yep, but clock on server 2 is wrong:
Quote Fri Jan 22 21:36:34 UTC 2010
Fri Jan 22 22:36:34 UTC 2010
Message 7 of 8
(523 Views)
Re: ccgi server down 8.45pm 22nd January - back up, but clock wrong
22-01-2010 9:46 PM
Clocks now OK:
Quote Fri Jan 22 21:45:39 UTC 2010
Fri Jan 22 21:45:40 UTC 2010
Message 8 of 8
(523 Views)
- Everything else
