ccgi server clock wrong (for the 5th time)
- Everything else
- ccgi server clock wrong (for the 5th time)
Re: ccgi server clock wrong
27-04-2009 1:14 PM
Quote from: MauriceC EDIT: It was further back than I thought http://usergroup.plus.net/pugit/view.php?id=174
Are you going to re-open that PUGIT as it is obviously not fixed?
28-04-2009 11:30 AM
28-04-2009 2:54 PM
I've found the problem, for those of you who are technically minded it was caused by ptn-ccgi03 having a corrupt /etc/adjtime file and a hardware clock set to UTC, when the server was booting it set the time to be 1 hour behind all of the others. I'll get a change raised this afternoon to get it sorted out so that it does not re-occur.
NTP is configured and running on all 4 ccgi servers and they all show exactly the same time now, I suspect that the slight time variations show earlier in this post were probably caused by the hardware clocks on all the servers being slightly out and so it has taken time for NTP to adjust the time so that they are all accurate.
[quote=http://ccgi.csogilvie.plus.com/dates.php]
I am running on: ccgi04.plus.net
Tue Apr 28 13:50:58 UTC 2009
Tue Apr 28 13:50:59 UTC 2009
09-05-2009 9:07 PM
Results of the clock ckeck show:
Sat May 9 20:01:17 UTC 2009
Sat May 9 21:01:18 UTC 2009
Sat May 9 20:01:19 UTC 2009
Server 2 is one hour forward.
This REALLY messes up my tracker system.
Tony
[EDIT] have also raised ticket number 28749306...
Re: ccgi server clock wrong (for the third time)
09-05-2009 9:52 PM
I wish I could name him, but I understand from posts in other topics that naming CS representatives is not the done thing.
Anyway... Thank you JS
Tony
11-05-2009 9:00 PM
Guess what, the server was brought back up and the clock was wrong.
I added to the ticket but nothing happened - no reply and no correction of the clock.
I phoned and told the CS operative that the clock was wrong and he said "yes, I can see it is wrong. I will get it corrected".
Nearly an hour after the phone call, it is still not corrected.
I will phone again, but I should not have to.
Tony
Re: ccgi server clock wrong (for the 4th time)
11-05-2009 9:12 PM
A note has been added to my ticket saying that they "will ask somebody to take a look at this for you".
Tony
11-05-2009 10:07 PM
12-05-2009 7:18 AM
Quote from: Duncan I've found the problem, for those of you who are technically minded it was caused by ptn-ccgi03 having a corrupt /etc/adjtime file and a hardware clock set to UTC, when the server was booting it set the time to be 1 hour behind all of the others. I'll get a change raised this afternoon to get it sorted out so that it does not re-occur.
Is NTP really running? Perhaps NTP is giving the wrong time....
Server 2 now seems to have had a "a corrupt /etc/adjtime file and a hardware clock set to UTC". If so, it is strange how the same fault occurs on a different server 2 weeks later.
Still angry - tracker statistics still being messed up 12 hours later...
Tony
12-05-2009 11:00 AM
See http://ccgi.csogilvie.plus.com/dates.php
Anyone CCGI users seeing different times reported by this tool for the four servers should raise a ticket.
12-05-2009 11:04 AM
12-05-2009 1:08 PM
I am running on: ccgi03.plus.net
Tue May 12 12:06:14 UTC 2009
500 Can't connect to 212.159.7.150:80 (connect: timeout)
Tue May 12 12:06:25 UTC 2009
perhaps there is some maintenance going on (like the clockl).
[Edit] - no current maintenance according to CS representative on support phone line..
12-05-2009 2:12 PM
Now all we need is an explanation.
12-05-2009 7:32 PM
The fixed them but server 2 clock is wrong again
Re: ccgi server clock wrong (for the 5th time)
13-05-2009 1:18 AM
Wed May 13 00:13:58 UTC 2009
Wed May 13 01:13:58 UTC 2009
- Everything else
