ccgi - new problems, ftp and http disagree
TomMelly
I had problems with the cgi server, so I backed up my stuff, disabled it, re-enabled it, and reloaded my files...
However, something's not right. I've got a simple index.html, but when I browse to http://ccgi.tomandlu.plus.com I see a completely different index. The correct one should say "Test Index - test index.html", but what I actually get is "It works!", and I can't even see where that file is coming from...
I seem to be hitting a completely different (wrong) directory via html...
Also, a minor oddity - for a moment I was able to log in via telnet, but now that's being refused - I've no idea whether telnet access is still supported or not, so I've no idea whether I was meant to be able to connect or not... all in all, a frustrating 48 hours...
Anyone got any ideas as to what's happening?
9 REPLIES 9
Gabe
Re: ccgi - new problems, ftp and http disagree
That's the page for the default vhost. It suggests that tomandlu is not currently mapped on ccgi - presumably a hangover from disabling your account. It should get re-added after a bit.
You shouldn't be able to get in by telnet. I hope that was a mirage or PN have a problem.
Gabe
TomMelly
Well, I've logged a support call, and something's happening, although still a work in progress... the telnet was bizarre (btw we did used to have telnet access a few years ago, didn't we?). There it was for a glorious five minutes - I was even able to cd .. out of my home directory and could see all the other home directories and their aliases...
Ooo! It's back...
cshell01.plus.net login: username
Password:
                _          _ _        _                        _
        ___ ___| |__  ___| | |  _ __ | |_  _ ___  _ __  ___| |_
        / __/ __| '_ \ / _ \ | | | '_ \| | | | / __| | '_ \ / _ \ __|
      | (__\__ \ | | |  __/ | |_| |_) | | |_| \__ \_| | | |  __/ |_
        \___|___/_| |_|\___|_|_(_) .__/|_|\__,_|___(_)_| |_|\___|\__|
                                |_|
    Welcome to cshell.plus.net!  Please ensure you read the helpful FAQs
    and the common CGI installation tutorials available via the portal
      at: http://www.plus.net/support/webspace/cgi_php/cgi_advanced_guide.shtml
        and: http://www.plus.net/support/webspace/cgi_php/cgi_scripts.shtml
    respectively for important information about this platform and how to
                      get your scripts going quickly!
username@cshell01:~$ pwd
/files/home2/username
username@cshell01:~$ ls -l ../ab*
ls: ../ab*: No such file or directory
username@cshell01:~$ cd ..
username@cshell01:/files/home2$ ls -l ab*
--- [ snip usernames ] ---
[Moderator's note by Dick (Strat) username removed from a public forum.
[color=green][Moderator's note by Barry Zubel: other usernames removed from a public forum.
Gabe
Houston ...
Gabe
jelv
Fixes: 10
I'm wondering if there are some IP ranges allowed in to allow PN staff access to the server.
Tom: are you on a fixed or variable IP? Could you post your current IP (with the last part masked) please
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
jelv
Fixes: 10
Can a moderator remove the names of the 13 users with names beginning ab from reply #2 please!
orbrey
Problem raised to our networks guys on this, thanks for the heads up all.
jelv
Fixes: 10
Thanks Barry!
TomMelly
I'm on a fixed IP - 84.92.***.**
I wonder if it wasn't just a side-effect of work PN were doing on my account (given I was having problems). It's not connecting now ("Connection refused by host").
All is now well, btw...
dick:green parts of IP address hidden in a public forum.
orbrey
Hi all, thanks for letting us know about this - our network engineers are about to roll a fix out to sort this. Should be done within the next hour or so.
