ccgi login
FIXEDTopic Options
- Everything else
- Re: ccgi login
23-05-2021 9:06 AM
Hello
I have not used ccgi control panel for some time and have forgotten the password.
Please help
Thank you
Fixed! Go to the fix.
Message 1 of 2
(556 Views)
1 REPLY 1
23-05-2021 9:28 AM
Have you tried using the forgotten password link? The username will be in the format 'ccgi.<plusnet_username>.plus.com'.
Message 2 of 2
(552 Views)
