ccgi fault
- Everything else
- ccgi fault
- « Previous
- 1
- 2
- Next »
Re: ccgi fault
27-09-2007 10:42 AM
I tried manually connecting and retrieving the CSS file from here and it says it doesn't exist. Just thought I'd add that to see if it's a location problem, before you reinstall it all
Message 16 of 22
(376 Views)
Re: ccgi fault
27-09-2007 11:01 AM
I have a php page on the plusnet CCGI server which accesses 2 external to PN MySQL databases via port 3306 and I can no longer connect to either.
Have you blocked external access on port 3306 from CCGI?
This was all working fine yesterday and nothing has changed as far as the website is concerned or the severs containing the external MySQL databases.
Message 17 of 22
(376 Views)
Re: ccgi fault
27-09-2007 11:10 AM
Hi Peter,
I've got a couple of the networks guys looking at this now, I'll let you know when it's sorted.
Message 18 of 22
(376 Views)
Re: ccgi fault
27-09-2007 11:12 AM
I can't get PHP include() to work with URLs, when it was working fine yesterday.
Anyone else experiencing this?
Message 19 of 22
(376 Views)
Re: ccgi fault
27-09-2007 11:14 AM
Yep, that's similar to the issue Peter is reporting and also reported in another thread. It's being looked at now.
*EDIT*
Should be fixed, looks like it was caused by the same maintenance as the other issues
*EDIT*
Message 20 of 22
(376 Views)
Re: ccgi fault
27-09-2007 11:19 AM
And as Sod's law would have it... I post a message then check back and it's working fine again!
I need to update my scripts to access the data using XML.
Thanks for the update!
Message 21 of 22
(376 Views)
Re: ccgi fault
27-09-2007 11:30 AM
Yep, MySQL access is working again now.
Message 22 of 22
(376 Views)
- « Previous
- 1
- 2
- Next »
