ccgi fault
nadger
ccgi fault
Just checked service status which reports no faults but unable to access my forum - quick ftp check also failed to connect.
21 REPLIES 21
flabbio
Re: ccgi fault
Yep. just confirmed that my CGI is un-FTP-able and cant get to forum on my cgi space either.
MikeWhitehead
Re: ccgi fault
http://usertools.plus.net/status/archive/1190867186.htm
I guess it's been delayed past the 6am that is noted on that service status notice.
ChemicalBrother
Re: ccgi fault
I've given someone up at PN towers a kick to find out what is going on....
flabbio
Re: ccgi fault
oops guess I should have checked for planned service outages before complaining  Undecided
Peter_Vaughan
Re: ccgi fault
Or get them by email here. Wink
nadger
Re: ccgi fault
Quote from: Peter
Thanks - just signed up  Smiley
graham
Re: ccgi fault
Why does CGI show as green when clearly, even if its just planned maintenance (thats now nearly 2.5 hours over due for finishing), it is not?
To indicate there is no problem with it, is misleading.
Chris
Legend
Fixes: 169
Re: ccgi fault
I've just tested this on my details and can log in now, I've also posted a retrospective SS about the problems.
http://usertools.plus.net/status/archive/1190880186.htm
glyndev
Re: ccgi fault
All is NOT right here. Can ftp to the server, but does not list files, or can't connect getting "Login inncorrect" even tried entering username and password manually.
Can browse site that is in root folder, but can't access a site in a folder.
Telnetted in and get "No directory. logging in with HOME=/
Chris
Legend
Fixes: 169
Re: ccgi fault
The ftp was caused by a similar issue. I've just tested from here and now get
230 User  logged in.
Remote system type is UNIX.
Using binary mode to transfer files.
Are you able to log in now too?
glyndev
Re: ccgi fault
Cheers chris.
Can login to ftp but still cant browse the mambo site http://ccgi.glyn-devonport.me.uk/mambo/. takes a long time to load then when loaded the page contains nothing, when I view the page source there is nothing there
James
Re: ccgi fault
I can load the site from this end.  Is there a lack of colour on it or is it not loading properly for me?
Chris
Legend
Fixes: 169
Re: ccgi fault
I've had a look at the site, it looks as though it's loading the body but not the style sheet. I've checked my forum which runs on the cgi servers and the style sheet is loading correctly for me.
glyndev
Re: ccgi fault
Thanks.
Its one that I loaded yesterday, worked ok then. I think that the best way may be to delete it and start from scratch.
As an aside I added a subdomain to DNS called guild.glyn-devonport.me.uk pointing to ccgi for this mambo site. Do I need to ask for DNS to be set to basic for it to work ?Huh
