ccgi allocation as opposed to www webspace.
- Everything else
- ccgi allocation as opposed to www webspace.
24-07-2008 6:52 PM
I've bitten the bullet and having tried and tested a new site completely in ccgi I have (after making sure all files are copied) deleted the contents of my htdocs folder :gulp:
After a few days I checked my webspace usage (giving it time to update the records) and sure enough 0% used from 250Mb.
Does anyone know how I can check how much space I've used in the ccgi? There is a link in the archive but it no longer works, so where can I find this information now?
Message 1 of 5
(1,549 Views)
4 REPLIES 4
Re: ccgi allocation as opposed to www webspace.
24-07-2008 7:27 PM
Login to the ccgi server and issue the following command;
du -sh
Message 2 of 5
(485 Views)
24-07-2008 10:33 PM
Hmmmm?
Done that and it says I have 250Mb? How can that be? There is quite a lot of stuff in there, so I must have less than 250Mb
Message 3 of 5
(485 Views)
24-07-2008 10:44 PM
Oooo
Just realised, that's how much I've used!!! Need to clear out some dross I guess. Ditto on other sites too.
Message 4 of 5
(485 Views)
10-08-2008 9:43 PM
Hello there,
Whoa! Major clean up eh xD
I've always used
although 'du' does look like quite a cunning command
Thanks for that one.
Cheers,
Jim,
I've always used
#> df
Cheers,
Jim,
Message 5 of 5
(485 Views)
- Everything else
