cannot upload to website
- Everything else
- cannot upload to website
21-11-2007 11:40 AM
I am trying to upload webpages using a ftp server terrapin onto my freeserve webspace for the first time, all I get is a message 'server refused list request'. anyone any ideas what ( i'm doing) is wrong.
Message 1 of 4
(1,487 Views)
3 REPLIES 3
Re: cannot upload to website
21-11-2007 12:13 PM
Try either a passive or active connection i.e the oposite of what you currently have set. You should be able to select this within the connection set-up pages (don't know the FTP client so can't be more specific).
Failing that, try the DOS command line version ftp.exe ( ftp <ftp URL> then enter username and password for your FTP connection)
I assume they allow connections from non-wanadoo connections?
Message 2 of 4
(285 Views)
21-11-2007 2:59 PM
Sorry if this is obvious, but it was a mistake I made at first. Make sure you're ftp'ing to the htdocs folder.
Message 3 of 4
(285 Views)
21-11-2007 3:02 PM
Quote my freeserve webspace
Might be worth contacting them to see if they allow connections from outside their network.
Message 4 of 4
(285 Views)
- Everything else
