blocked Plusnet OMG
wizardcarwash
blocked Plusnet OMG
I'm trying to access a simple uk site called Friday Ad
plusnet is blocking how do i fix this
jesus its all worked fine until 3 days ago
what is going on
Moderator's note by Mike (Mav): Avoidance of swear filter in title edited as per Forum rules.
15 REPLIES 15
Mav
Fixes: 511
Re: blocked Plusnet OMG
I have no problems accessing the site from my PN connection. Have you tried using Google's DNS?
8.8.8.8
8.8.4.4
Forum Moderator and Customer
wizardcarwash
what is google DNS  ?
I'm a mechanic not a Geek cheers Smiley
wizardcarwash
Hmmm... cannot reach this page
Try this
Details
bobpullen
Fixes: 307
What makes you think Plusnet are blocking access to the site? Are you seeing some sort of notice that suggests this is what's happening?
wizardcarwash
Try this
Details
bobpullen
Fixes: 307
Ah, that's Safeguard.
You can either disable it, or add the site you're trying to access to the whitelist.
You can access the settings by logging into the main Plusnet website and clicking the 'Safeguard' link on the left.
Pete11
Seasoned Pro
Fixes: 4
The site works for me using Plusnet. Some interesting stuff on there.  Thumbs_Up
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
bobpullen
Fixes: 307
@Anonymous, jeez someone got it of the wrong side of bed this morning 😉
Access is being blocked by our parental control filter. The solution is as simple as disabling it/adding an exception.
No need to be fiddling with DNS at all.
wizardcarwash
How do I find it
have never touched the parental control filter
let me look
so i have googled and logged in
this is what i have cut and pasted
Plusnet Access Control: Disabled
Configure
My Home Network
Devices currently connected to your Plusnet Hub:
Network Device MAC Address IP Address
2.4 GHz Wireless: EPSON628DAC 64:eb:8c:62:8d:ac 192.168.1.83
  android-60d3bc11c... f4:0e:22:e6:c3:8b 192.168.1.74
5 GHz Wireless: Samsung-Galaxy-S7... 2c:0e:3d:3b:de:ed 192.168.1.67
Ethernet: udhcp-0-9-9-pre-5... 54:c4:15:e4:b2:f4 192.168.1.66
  DESKTOP-ISONQ2P b8:97:5a:3e:b4:5d 192.168.1.73
USB: No devices detected
wizardcarwash
Use Access Control to set times when specific devices will be prevented from connecting to the internet.
This can be useful if you'd like to control the amount of time your children are online. This means the Plusnet Hub will block all incoming and outgoing traffic to specific devices between the hours you select.
Access Control feature enable: Option Yes for access control enabled is unselectedOption No for access control enabled is selected
Current time: 10:09
  Internet blocked between Permanent
Disable access for all devices: Option Yes for access control all enabled is unselectedOption No for access control all enabled is selected
click to change hours start all
and
click to change hours end all
Device Internet blocked between
click to change devices dropdown
Add
No Access Control currently selected
Apply
Cancel
Waiting Applying...
bobpullen
Fixes: 307
@wizardcarwash, sorry perhaps I should have been clearer.
I'm talking about our server-side parental control filters, not those in the router interface.
You can access them here.
I've just checked, and the site you're trying to access is being categorised under 'Tasteless', so either add an exception under the 'allow website' section, unblock the 'Tasteless' category, or switch off the filter in its entirety - up to you.
You're given a choice about enabling or disabling this service during the sign-up journey, so I can only guess that's when it was enabled.
ScottStorey
It looks to be a free ads type site Bob.
Sounds like safeguard has got it wrong as the root cause.
bobpullen
Fixes: 307
I'd say that depends what people are advertising 😂
On a serious note, I'll take a look if I get the chance and submit a request to change the catagorisation if necessary.
rongtw
Fixes: 12
@ScottStorey its a bit iffish ,, if you look there is a adult only adverts Sad
