backups
- Everything else
- backups
backups
17-08-2010 7:56 PM
I know that I should have done it sooner rather than pray to the great god of backup for forgiveness after the event! Well I think I might have caught this one in time if you can help?
I need to backup all the files I have on the CGI server, some are php but there are a load of uploaded photographs as well. In addition I need to backup the data held in MySQL. The question is what is the best tool for the job. I would have used the SSH login if it was available but since that is no longer an option, any ideas?
Message 1 of 5
(1,008 Views)
4 REPLIES 4
Re: backups
20-08-2010 1:00 PM
Hi Tony,
I guess backing up the db you'd still do using phpmyadmin export tab at https://mysql.plus.net/
For the rest, no login, but you can run non-interactive shell scripts like
(tar.cgi upload as ascii and set mode 0700 then request in browser) would pack up your foo folder into foo.tar.gz and
would unpack it again. Down/upload and delete using ftp. Not most elegant but works.
Gabe
#!/bin/bash
echo "Content-type: text/plain"
echo
tar -cvvzf foo.tar.gz foo/
#!/bin/bash
echo
tar -xvvzf foo.tar.gz
Gabe
Message 2 of 5
(258 Views)
Re: backups
20-08-2010 2:13 PM
You could do something like this in a similar vein, but includes the mysql databases and emails the finished file to you.
I've just knocked this up off the top of the head so it might need some tidying and testing, but it should work,
#!/bin/bash
echo
# Add in your mysql details here
MYSQL_USER=
MYSQL_PASSWORD=
MYSQL_DATABASE=
# Add in your email address
EMAIL=
BACKUPFILE=backup.tar.gz
DATE=$(date +'%Y-%m-%d')
BOUNDARY=$DATE/backup+++
cd ~
mysqldump --opt -u$MYSQL_USER -p$MYSQL_PASSWORD $MYSQL_DATABASE > $MYSQL_DATABASE.sql
tar -cvf - . | base64 > $BACKUPFILE.base64
rm $MYSQL_DATABASE.sql
cat <<EOF> $BACKUPFILE.head
MIME-Version: 1.0
Content-Type: multipart/mixed; boundary="$BOUNDARY"
This is a multipart message in MIME format.
--$BOUNDARY
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 7bit
Please find backup.tar.gz attached
--$BOUNDARY
Content-Type: application/octet-stream; name="$BACKUPFILE"
Content-Transfer-Encoding: base64
Content-Disposition: attachment; filename="$BACKUPFILE"
EOF
cat $BACKUPFILE.head $BACKUPFILE.base64 | mailx -s "Daily backup for $DATE" $EMAIL
rm $BACKUPFILE.head $BACKUPFILE.base64
Message 3 of 5
(258 Views)
Re: backups
20-08-2010 3:16 PM
Quote from: Ben I've just knocked this up off the top of the head
And remembered to base64 the thing on a Friday afternoon.
Gabe
Message 4 of 5
(258 Views)
Re: backups
22-08-2010 6:18 PM
Duly deFridayed and tested a bit:
Gabe
#!/bin/bash
echo
MYSQL_HOST=
MYSQL_USER=
MYSQL_PASSWORD=
MYSQL_DATABASE=
EMAIL=
# Select files to backup
# . backs up everything
# or select files and folders
# between quotes, e.g.:
# "mysql_backup.sql wordpress/wp-content/ foo.txt bar/foo.txt"
BACKUPFILE="mysql_backup.sql"
# Nothing more to add
cd ~
mysqldump --opt -h $MYSQL_HOST -u $MYSQL_USER -p$MYSQL_PASSWORD $MYSQL_DATABASE > mysql_backup.sql
cat <<EOF> tmpfile.txt
To: $EMAIL
Subject: Backup on $DATE
MIME-Version: 1.0
Content-Type: multipart/mixed; boundary=$DATE-backup
--$DATE-backup
See attached.
--$DATE-backup
Content-Type: application/x-tgz
Content-Disposition: attachment; filename=backup.tar.gz
EOF
tar -cvzf - $BACKUPFILE | base64 >> tmpfile.txt
cat <<EOF>> tmpfile.txt
--$DATE-backup--
EOF
cat tmpfile.txt | /usr/sbin/sendmail -t -i
rm tmpfile.txt mysql_backup.sql
echo "Backup sent to "$EMAIL
Gabe
Message 5 of 5
(258 Views)
