analogue alarm autodialler
brun0
Hi all
I have now got FTTP, so the old landline is gone, my problem is that I have got an analogue auto dialler fitted to my security alarm. Is there a way to connect this to the Hub 2, I've noticed on the back of the hub2 that there is a telephone jack socket, can this be utilised. As I understand this port is already configured for ATA, can I just plug the AD into this?🤔
6 REPLIES 6
Fixes: 558
Re: analogue alarm autodialler
Plusnet do not provide a digital voice(voip) service and so that port is not configued on the Hub.
You could buy a separate ATA ( something like this https://www.amazon.co.uk/Grandstream-HT801-SIP-ATA-HandyTone/dp/B06XW1BQHC/ref=asc_df_B06XW1BQHC/?ta... ) and connect your alarm to that, but you would also need a voip account. You would also need to check whether the alarm system uses pulse or tone dialiing and make sure the ATA can support it.
If your autodialler is a simple one which just dials the programmed number ( not a monitoring service ) then you would probably get away with using a free payg voip account from the likes of localphone ( localphone.com )
brun0
Thanks MisterW, the AD uses tone dialling and can send SMS texts, so I've programmed it to ring and send a text to my mobile number. I will check out those links you provided.👍
Fixes: 558
can send SMS texts
How did it do that from a landline ? did it use the standard BT text service ?
That will be a problem when using a voip service
Mav
Fixes: 518
Moderator's note(s):
Thread moved from Full Fibre to Everything Else.
Forum Moderator and Customer
brun0
The AD (Texecom speech & text dialler) dials a texting service first
Fixes: 558
Ok, that may still work, as long as nothing in the system is relying on being associated with your old landline number and sending that as the CLI
