active-scripts guestbook
- Everything else
- active-scripts guestbook
09-11-2007 11:08 AM
has anyone installed active-scripts free cgi guestbook..
http://www.active-scripts.net/active_guestbook.html
i have done a vanilla install as they suggest into my cgi-bin area and i can reach the guestbook using the url, yet when i try to enter details and press submit i get a server error...
20e
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, webmaster@plus.net and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
0
I would appreciate any advice...
regards
Re: active-scripts guestbook
09-11-2007 12:21 PM
have you CHMOD 775 the file?
Post a link to the page so we can take a look.
09-11-2007 12:50 PM
I loaded the software into my cgi area but was using the url of myowndomain
ie http://www.mydomain.co.uk/cgi-bin/guestbook/guestbook.cgi which brought up a page but wasnt working correctly..
i then used http://ccgi.username.plus.com/cgi-bin/guestbook/guestbook.cgi and that works just fine.
I suppose really i need to find out if i can use ccgi part with my oown domain name ie cggi.mydomain.co.uk
thanks
09-11-2007 2:04 PM
Possibly someone can help to alter the .htaccess so that it will work for you (/cgi-bin/guestbook/).
09-11-2007 8:21 PM
10-11-2007 9:10 AM
Now what if i have a couple of websites and want a guestbook on both do i just add the sameas above and index them i.e guestbook and guestbook1 or is there any otherway. Thanks again regards Andy
11-11-2007 9:13 PM
11-11-2007 9:52 PM
31-12-2007 5:31 PM
After all that though, I'm tending to move towards CMS now and there's loads of free stuff available for Joomla CMS and it's faily painless to get into.
My joomla site is a bit of a hybrid at the moment putting Active scripts pages into a 'wrapper' on the site until I get proper Joomla pages sorted for the same things.
You can see both in operation here:- http://www.bromsgroverfc.co.uk
31-12-2007 5:49 PM
It is php based and anyone making an entry needs to read the image text and enter it to proceed.
Its easy to set up and works like a charm.
31-12-2007 6:18 PM
01-01-2008 8:49 PM
The first guestbook I ever used was a perl scripted one, and in the end I got fed up of editing its pages to remove the links to porn sites that were appearing several time a day.
The one I use now doesn't allow direct links and if anyone persists and actually goes to the trouble of trying to manualy write in a url its very easy to remove the entry with a click of the mouse.
- Everything else
