Zippyshare blocked?
- Everything else
- Re: Zippyshare blocked?
Zippyshare blocked?
10-03-2019 3:46 PM
Im wondering are Plusnet now actively blocking Zippyshare.com?
Its a file hosting website its likely used for piracy in some way but most people use it for legit reasons and since around thursday myself and most people in the uk are getting a 403 Forbidden error.
Is this a nationwide block or an issue with the filehost? i can view the website perfectly fine via VPN which suggests its being blocked.
10-03-2019 4:15 PM
Moderators Note
This topic has been moved from Fibre to Everything Else
10-03-2019 4:17 PM
I think it's an issue with ZippyShare - I can access it with an overseas VPN but not when that VPN is routed through a UK server.
So you need to reach out to them in some way and ask why they are blocking uk traffic.
10-03-2019 4:28 PM
Never used it myself, though posting to confirm it's also forbidden.
If this helps, it does look like something in France, possibly onwards...?
C:\WINDOWS\system32>tracert Zippyshare.com
Tracing route to Zippyshare.com [145.239.9.15]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms dsldevice.lan [172.16.0.1]
2 * * * Request timed out.
3 * * 10 ms 141.hiper04.sheff.dial.plus.net.uk [195.166.143.141]
4 11 ms 11 ms 12 ms 140.hiper04.sheff.dial.plus.net.uk [195.166.143.140]
5 11 ms 10 ms 11 ms 195.99.125.142
6 11 ms 14 ms 12 ms peer8-et-0-1-7.telehouse.ukcore.bt.net [194.72.16.146]
7 12 ms 12 ms 12 ms ldn-5-a9.uk.eu [54.36.50.114]
8 16 ms 16 ms 70 ms be100-1042.rbx-g2-nc5.fr.eu [213.251.130.102]
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 15 ms 14 ms 14 ms ns3081896.ip-145-239-9.eu [145.239.9.15]
10-03-2019 4:37 PM
traceroute to zippyshare.com (145.239.9.15), 30 hops max, 60 byte packets
1 vss-1-6k.fr.eu (94.23.41.253) 0.447 ms 0.452 ms 0.472 ms
2 10.95.68.192 (10.95.68.192) 0.275 ms 0.232 ms 0.188 ms
3 10.95.66.70 (10.95.66.70) 0.278 ms 10.95.66.76 (10.95.66.76) 0.275 ms 10.95.66.78 (10.95.66.78) 0.223 ms
4 10.73.16.49 (10.73.16.49) 0.539 ms 10.73.16.51 (10.73.16.51) 0.654 ms 10.73.16.55 (10.73.16.55) 0.516 ms
5 10.17.113.9 (10.17.113.9) 0.279 ms 10.17.113.11 (10.17.113.11) 0.328 ms 10.17.113.9 (10.17.113.9) 0.283 ms
6 10.50.168.69 (10.50.168.69) 0.823 ms 0.783 ms 0.838 ms
7 ns3081896.ip-145-239-9.eu (145.239.9.15) 0.220 ms 0.346 ms 0.302 ms
10-03-2019 5:30 PM - edited 10-03-2019 5:37 PM
Just tried on my phone data (not Plusnet) and get a 403 forbidden there too.
From my server company ...."403" is actually an HTTP status code that means that the web server has received and understood your request, but that it cannot take any further action. UK Block, maybe.
I see on Virgin Media they have the same problem although someone says they can access it on PN and Vodafone (which seems a little strange as my phone ports via Voda). There is supposedly a fix here #6
10-03-2019 5:38 PM
10-03-2019 6:29 PM
The usual countrywide block would have a message saying so.
So as said I assume it's being blocked at source.
10-03-2019 6:59 PM
Found a plausible answer on Wiki - https://en.wikipedia.org/wiki/List_of_websites_blocked_in_the_United_Kingdom
Resolved and erroneous blocks
Zippyshare - blocked by mistake - since 08/03/19 - blocked by ISPs - at the time of posting unresolved
10-03-2019 7:58 PM
Also VPN servers aren't subject to blocking so should be able to access it.
10-03-2019 8:14 PM
I was merely pointing out that if it's on Wiki, then it must be true, so I have to believe it!!
(guess I should of made that a bit clearer )
I do agree it's at their end, this does show it's currently up - https://www.isitdownrightnow.com/zippyshare.com.html
15-03-2019 8:56 PM
20-08-2019 9:14 PM
Ah, now it makes sense. I've been attempting to visit zippyshare.com for the past 20 minutes or so and couldn't work out what the problem was. I deleted my cache cleared cookies etc and checked the site was up with https://downinspector.com/check/https://www.zippyshare.com. They've blocked Germany and Spain along with the UK too.
Hopefully, there's a decent quality free VPN I can use.
- Everything else
