Zencart on Plusnet?
- Everything else
- Zencart on Plusnet?
Zencart on Plusnet?
07-04-2008 12:17 AM
I need to move my shop and thought as I have webspace with Plusnet I would look into putting it there.
Can anyone tell me if Plusnet supports Zencart now?
If it is supported how do I go about moving it over?
Many Thanks
Sarah
http://www.helshopcrafts.co.uk
Re: Zencart on Plusnet?
07-04-2008 8:16 AM
Answer - or shall I say probable answer, Plusnet is not primarily a program hosting service and does not encorage business web sites, you can have a link from your web space to programs stored on other servers, but I dont think that is what you want. Also form first looks your total site would not fit onto the available space you are allocated on PN Servers
Sorry
Wait for an official answer later today
07-04-2008 8:20 AM
I'll see if I can find someone that might know though.
07-04-2008 8:43 AM
07-04-2008 8:49 AM
Quote On August 12, 2007, Zen Cart team announced that the future versions of the software, starting with 1.4.0 will require PHP 5.2 as a minimum.
07-04-2008 8:53 AM
Quote <!--bof- site copyright display -->
<div id="siteinfoLegal" class="legalCopyright">Copyright © 2008 <a href="http://www.zen-cart.com" target="_blank">Zen Cart</a>. Powered by <a href="http://www.zen-cart.com" target="_blank">Zen Cart</a></div>
<!--eof- site copyright display -->
07-04-2008 8:58 AM
Look at the bottom of this page - you'll see that SMF own the copyright to the forum software used here.
Any company producing software for folks to use in their webspace will likely maintain copyright of the software - doesn't stop them selling it or allowing folks to use it free under license though.
07-04-2008 9:03 AM
07-04-2008 9:12 AM
Quote Zen Cart™ truly is the art of e-commerce; free, user-friendly, open source shopping cart software. The ecommerce web site design program is being developed by group of like-minded shop owners, programmers, designers, and consultants that think ecommerce web design could be and should be done differently.
You should also be aware that there does not appear to be any link between Zen-cart and the ISP Zen.
07-04-2008 9:15 AM
07-04-2008 9:21 AM
Seems the current version of Zencart works fine on Plusnet.
B.
07-04-2008 11:39 AM
07-04-2008 12:39 PM
