Yet another Freenetname/Madasafish domain name not renewing
PSalmons
I've had my domain name of psalmons.co.uk  for many years and via several providers, Freenetname, Madasafish, and now yourselves.  In common with some others it seems, I've just received the following email
Your domain name is expiring
We are writing from Nominet, the internet registry for .uk domains. Your registrar automatically registers your domain name with us on your behalf when you purchase your domain name. We are writing to inform you that your domain name psalmons.co.uk has expired and that you need to renew the domain if you wish to continue using it.
To renew your domain name, you will need to contact your registrar, and they will arrange this for you. Domain names can be renewed for up to 10 years, and they will be able to offer information on a suitable duration of renewal as well as other questions you might have regarding your domain.
Can you help, please?
Best regards
6 REPLIES 6
MatthewWheeler
Fixes: 437
Re: Yet another Freenetname/Madasafish domain name not renewing
Thanks for getting in touch @PSalmons.
I've raised this to the relevant team for your domain to be renewed and we'll update you as soon as possible
Apologies for any inconvenience caused
 Matthew Wheeler
PSalmons
Many thanks, Matthew.  Can you also tell me if, after the problem is fixed, it will automatically renew in future?
Best regards,
Paul.
MatthewWheeler
Fixes: 437
Thanks for getting back to us @PSalmons
I'm afraid you'll most likely have to contact us again in a years time
 Matthew Wheeler
PSalmons
OK.  Thanks, Matthew.  I've put it on the calendar.  At least it won't come as such a shock next time.
Regards,
Paul.
PSalmons
I've just seen the little green tick and checked "whois," and my domain is registered again.  Many thanks for the prompt and efficient service.
Regards,
Paul.
LaurenB
Fixes: 131
Hi @PSalmons, I'm glad this is sorted, please just get back to us if you have any further queries.
 Lauren Barry
