Yahhoo prventing e.mail msage
- Everything else
- Re: Yahhoo prventing e.mail msage
on 16-08-2017 6:10 PM - last edited on 16-08-2017 6:19 PM by Mav
I have used Yahoo e,mail since the late 90's and am to old to start a new e.mail service address etc. I have recently received a series of messages saying they have "prevented a sign in attempt from an app that does not meet modern security standards to my Yahoo account and suggest switch to a yahoo account on each occasion they lay the blame at the door on IP [Removed]. A search shows this to be Plusnet address. as it seem impossible to telephone plus net with such a problem or send an e.mail with more that 150 characters including blanks I wonder if anyone of you boffins has an answer to this problem. OpportuneS20
Moderator's note by Mike (Mav): IP address removed from a public forum to an area that staff can see.
18-08-2017 7:00 PM
Also what Apps / programs do you use to access your yahoo email account?
22-08-2017 2:29 PM - edited 22-08-2017 2:31 PM
I'm not totally sure if you're complaining of unauthorised access attempts or being blocked.. if its the latter then there is a setting for that which Yahoo introduced silently ages ago and activated it for everyone by default. Making it worse they hide it rather well.
Here's the steps to disable it:
Login to http://mail.yahoo.com
Go to the "account into" link at the bottom of the settings menu:
You will probably be asked to confirm your password at some point.
Next click on "Account security":
Scroll down right to the bottom and you'll find a section called "Allow apps that use less secure sign-in"
Click the switch to turn it on:
Now you'll be able to use ordinary Outlook express, thunderbird, Outlook, Windows Live etc without all the new overly complex security stuff. You'll still need to enable SSL / TLS but those older clients support that so you'll be ok.
Hope that helps!
- Everything else
