Wordpress - rich text editor not showing in admin
- Everything else
- Re: Wordpress - rich text editor not showing in ad...
22-06-2011 10:03 AM
Hi, I've had this problem before and can't remember how it was solved. Installed wordpress on ccgi using the guide in this forum and the file permissions script. However when I try and create a page/post, there is no rich text editor. Is this a further file permission problem? Many thanks in advance...
Message 1 of 6
(2,970 Views)
5 REPLIES 5
Re: Wordpress - rich text editor not showing in admin
22-06-2011 12:34 PM
If you display your admin profile is "Disable the visual editor when writing" checked?
David
Message 2 of 6
(902 Views)
22-06-2011 1:00 PM
Hi
No it's not checked - I've already looked here!
Any other suggestions? I know I've sorted this before on another site here but can't remember what I did...
Message 3 of 6
(902 Views)
22-06-2011 2:04 PM
Googling suggests this was a regular problem with WordPress releases around version 2.8.x. For instance here. However didn't spot any recent mentions. Are you using the current 3.1.3 version?
You could try *disabling* the visual editor and save the change. Log out and clear the browser cache, Then login and enable the editor again.
Corrupted files in the wp-admin or wp-includes folders appear to be another possibility. When you installed the package were all text files uploaded as ASCII? You could try an automatic re-install (run the permissions script again before returning to the dashboard if you try that).
David
Message 4 of 6
(902 Views)
22-06-2011 4:33 PM
Hi
I am using the latest version of wordpress. I've tried disabling, logging out and clearing cache - still not working. All text files were uploaded as ASC11. I'd rather not re-install if possible. I'm sure it was something easy last time but can't find the old post - or maybe I used a live chat? Will re-install if that is the case but anyone else had this problem???
Message 5 of 6
(902 Views)
22-06-2011 8:01 PM
Are the permissions on all files of types other than .php, .pl and .cgi (in particular .js (JavaScript) and image files) set to 0640? And directories at least 0710 (wp-content/upload and its subdirectories 0750)?
David
Message 6 of 6
(902 Views)
- Everything else
