Wordpress help needed
- Everything else
- Wordpress help needed
10-11-2010 10:47 PM
Warning: require_once(/share/storage/04/ya/yaptondesigns/wordpress/wp-includes/cache.php) [function.require-once]: failed to open stream: Permission denied in /share/storage/04/ya/yaptondesigns/wordpress/wp-includes/load.php on line 361
Fatal error: require_once() [function.require]: Failed opening required '/share/storage/04/ya/yaptondesigns/wordpress/wp-includes/cache.php' (include_path='.:/usr/share/php:/usr/share/pear') in /share/storage/04/ya/yaptondesigns/wordpress/wp-includes/load.php on line 361
Can someone tell me what I need to do to sort this out?
Re: Wordpress help needed
10-11-2010 11:16 PM
Also the permissions on the uploads folder within wp-content need to be 750 to ensure uploaded images can be seen - but installation needs to be completed before that matters.
10-11-2010 11:31 PM
All Folders (directories) should be set to 710
All Script files (.php) should be set to 700
All Static files (.htm .html .css .txt .png .jpg .gif .js) should be set to 640 (note javascript (.js) is treated as a text file by the server)
11-11-2010 1:15 PM
Do all your files and directories have group set to cgiusers?
11-11-2010 4:38 PM
Excuse my ignornace but I am new to this as far as I know yes but how do I check?
11-11-2010 7:12 PM
11-11-2010 11:57 PM
12-11-2010 1:34 PM
Has installation of any packages such as this one been successful in your ccgi webspace?
12-11-2010 9:26 PM
13-11-2010 11:13 PM
Then run the setperms.cgi program posted here to set file and directory permissions appropriately. (Did you use that last time?)
After that try the install script again.
16-11-2010 3:27 PM
16-11-2010 4:27 PM
Don't forget that the directory /wordpress/wp-content/uploads needs permissions set to 750 (rather than 710). It's possible that this directory won't exist until something (eg an image) is uploaded, but if so I suggest creating it using your FTP program so that it is ready for uploads.
17-11-2010 8:38 AM
