Wordpress Install
- Everything else
- Wordpress Install
Wordpress Install
24-10-2008 3:20 PM
I am trying to install Wordpress. I've setup the database, downloaded the files and enabled php scripts to execute by running "fixphpperms.sh -c".
However, when I try to run the install script by accessing it through the browser ".........wp-admin/install.php" it attempts to download the file instead of executing the script.
I am assuming/guessing the execution of scripts isn't allowed (despite having run the appropriate command).
Hope that is clear.
Any help would be very welcome,
WannabeeBlogger
Hope that is clear.
WannabeeBlogger
Message 1 of 4
(1,026 Views)
3 REPLIES 3
Re: Wordpress Install
24-10-2008 4:02 PM
That behaviour is symptomatic of PHP not being recognised as a scripting language - if you are using Plusnet's normal host, at a guess you are NOT running on the CCGI server (but should be).
Quote from: WannabeeBlogger ...
Message 2 of 4
(119 Views)
24-10-2008 4:11 PM
Pod, thanks. That sounds very likely. I'll follow up and let you know.
Cheers
Cheers
Message 3 of 4
(119 Views)
24-10-2008 4:28 PM
Pod,
You were right, I was on the wrong servers. Sorted now. Thanks for the prompt response.
Message 4 of 4
(119 Views)
