Wordpress Blog – raising the dead
FIXED- Subscribe to RSS Feed
- Everything else
- Wordpress Blog – raising the dead
13-03-2020 12:27 PM
Not sure if this is the right board, but … please tell me if not.
I’m trying to set up a new replacement database in phpMyAdmin for a broken blog.
If I try to create a new database preparatory to importin a *.sql file, I get #1044 Access denied.
I do have an unused empty database which I could use but if I try to import my *.sql file into this it spends about five minutes working on it — its 38mb, then I get the green notice saying that the import has been successful, but when I open the database there are no tables.
I will be most grateful for any help.
Fixed! Go to the fix.
Re: Wordpress Blog – raising the dead
13-03-2020 2:02 PM
So you’ll have to cope on your own. Sorry guys reality has taken over.
14-03-2020 7:31 AM
14-03-2020 11:20 AM
Many thanks spraxyt (you kindly helped me once before I think) but I’m afraid that I’m more used to dealing with this kind of thing on localhost (XAMPP) than on the PlusNet server, where the interface has changed some since I was last there. So I hate to ask this, but which ‘control panel app’, where ?
14-03-2020 12:06 PM
The app is the DB Manager
16-03-2020 12:32 PM
That's the answer!
I was logging in via a direct shortcut that Bob Pullen gave me long, long ago, which was to ccgi.<me>.plus.net/phpmyadmin. Hence the problem making changes when I got there, as you pointed out.
Many thanks again and I'm sorry it was such a dumb question.
16-03-2020 12:45 PM
16-03-2020 1:42 PM - edited 16-03-2020 1:46 PM
Mortified! I just clicked the button when I saw it.
Have now cancelled it and will register a fix for spraxyt. Thanks for putting me right.
- Everything else
