Wordpress 3.2 and higher
- Everything else
- Wordpress 3.2 and higher
05-07-2011 10:16 AM
Wordpress 3.2 has just been released and requires PHP 5.2.4 and MySQL 5.0.
As of 5 July 2011, the Plusnet MySQL servers are still running v 4.1, so automatic updates to WP 3.2 will fail.
Fortunately, WP 3.1.4 contains all of the security enhancements of WP 3.2, so there's no immediate security imperative to upgrade.
But if you do need or want to upgrade for other reasons, you can backup (!) and upgrade manually, following instructions here, but edit wp-includes/version.php, replacing the line
$required_mysql_version = '5.0';
with
$required_mysql_version = '4.1';
After Step 1 (1-6), reset permissions on the site.
This only works because, so far, in WP 3.2 only the MySQL version checks have changed. The code to use MySQL 4.1 remains.
But, use of WP 3.2 with MySQL 4.1 is not supported and later versions of WP 3.2.x may become genuinely incompatible with MySQL < 5.0 without notice. Ditto third-party add-ons.
Possibly Plusnet may soon think again about upgrading the MySQL platform. Ever the optimist
Gabe
Re: Wordpress 3.2
05-07-2011 4:52 PM
Re: Wordpress 3.2
05-07-2011 7:36 PM
Re: Wordpress 3.2
13-08-2011 12:21 PM
A question for Plusnet staff. Will MySQL under Plusnet hosting be upgraded at any time this decade and if so what are the planned timescales.
Re: Wordpress 3.2
17-08-2011 6:34 PM
Normally I would start a new thread but Tech Support seem to be implying that the problem is related to updating Wordpress and actually point to this thread in their response as well as the Wordpress manual update page.
Re: Wordpress 3.2
17-08-2011 7:07 PM
I originally installed 3.2 using Gabe's work-around, manually updated to 3.2.1 because different version-check code is involved and patching that failed due to the relevant file being replaced during update. However I would expect a (patched) 3.2.1 installation to be OK.
I suspect your problem is nothing to do with WordPress.
Re: Wordpress 3.2
17-08-2011 8:24 PM
Re: Wordpress 3.2
08-11-2011 12:12 PM
One thing that is slightly different is that the ...mysql_version in version.php should now read
$required_mysql_version = '4.1.11';
mysql.plus.net is also working.
many thanks
Re: Wordpress 3.2
13-12-2011 10:08 AM
Gabe
Re: Wordpress 3.2 and higher
29-12-2011 10:02 AM
Server error!
The server encountered an internal error and was unable to complete your request.
Error message:
Premature end of script headers: index.php
If you think this is a server error, please contact the webmaster.
Error 500
ccgi.btbonline.plus.com
Thu Dec 29 09:49:00 2011
Apache
If there's no way round this I 'll have to regress it to 3.2, unless I have missed something.
Andy
29-12-2011 11:47 AM
Presumably you reset file permissions to the correct ones?
29-12-2011 3:23 PM
I did reset the perms (been caught by that one before) and yes I did unpack the zip on my PC and then transferred over using CuteFTP. The .htaccess looks ok but I'll check for CRLFs - would that affect all php files potentially?
Andy
29-12-2011 5:32 PM
Gabe
29-12-2011 8:07 PM
30-12-2011 12:30 PM
Gabe
- Everything else
