Wordpress 3.1 Virus
- Everything else
- Wordpress 3.1 Virus
Wordpress 3.1 Virus
07-05-2014 4:56 PM
I inherited a website from a previous designer and I'm no expert but...
All seemed to go well for a few weeks after the CGI switchover but now Avast is detecting a virus whenever I access the Wordpress management URL (http://www.bondhaygolfclub.com/wordpress/wp-login.php)
The avast infection is
JS:Includer-BCC [Trj] at URL h_wdrsm_hikonefabebppd_com__f4i9cbk46k|{gzip}
The Wordpress dashboard seems to work OK but it displays the following in several places:
'/'); define('CONCATENATE_SCRIPTS',false); require_once(ABSPATH.'wp-settings.php'); ?>
Wordpress version is 3.1 but I am nervous about updating as last time I did this it messed up file protections & the website stopped working - I seem to recall having to run a script by Gaby to reset permissions
Is there any problem doing an auto upgrade to v3.9?
Message 1 of 6
(1,879 Views)
5 REPLIES 5
Re: Wordpress 3.1 Virus
07-05-2014 6:07 PM
Make sure you take a backup of the site and the db before you do the upgrade so you can restore afterwards if it breaks. 3.1 is pretty old!
Kelly Dorset
Ex-Broadband Service Manager
Message 2 of 6
(262 Views)
07-05-2014 6:09 PM
Spotted this: https://www.youtube.com/watch?v=FjUsw4Fkxl4
No idea if it is helpful.
Kelly Dorset
Message 3 of 6
(262 Views)
07-05-2014 7:58 PM
Quote from: Kelly Make sure you take a backup of the site and the db before you do the upgrade so you can restore afterwards if it breaks. 3.1 is pretty old!
I use the XCloner plugin for this. Nice and simple to use and saves site and Database in one pass.
HTH
Message 4 of 6
(262 Views)
07-05-2014 9:35 PM
Thanks MauriceC looks good
Message 5 of 6
(262 Views)
11-05-2014 4:21 PM
Thankyou
Restored wordpress php files from copies & virus disappeared
Upgraded Wordpress to 3.9 automatically with no problems & done a XCloner backup
all seems OK now
all seems OK now
Message 6 of 6
(262 Views)
