Will OpenDNS work with the Plusnet Hub One router
tcj1971
As the title says
Getting absolutely nowhere with Plusnet Safeguard. It simply does not work - well not for me anyway trying to block social media sites or any other www. for that matter
Anyone point us in the right direction with Open DNS to work with the Plusnet Hub One?
2 REPLIES 2
Browni
Aspiring Hero
Fixes: 52
Re: Will OpenDNS work with the Plusnet Hub One router
One problem, you can't change the DNS servers on a Hub One...
tcj1971
Thanks. So that is a no then
Safeguard is a waste if space. Does it actually work or is there something I am not doing? As seen in my other thread about Safeguard Safeguard-Not-Working-Blocking-Websites
