WiFi calling on mobile?
Kalabata
I am planning to move to Plusnet Full Fibre 74. I don't have a landline. Will I be able to connect my mobile to the Plusnet Wifi for WiFi voice calls. ( The phone's settings have Wifi calling enabled ). Many thanks.
5 REPLIES 5
Fixes: 1,495
Re: WiFi calling on mobile?
Moderators Note
This topic has been moved from Broadband to Everything Else
Fixes: 1,495
Yup, I have a Vodafone mobile with Wifi calling enabled and it works fine.
Fixes: 580
@Kalabata as @dvorak says , it will work as long as your mobile provider supports wifi calling. Who is your mobile provider ?
Kalabata
Thanks, my mobile provider is Smarty ( they use 3 network )
Fixes: 383
You do have Wi-Fi calling then, so long as your phone supports it.
