Which Perl modules are currently installed?
- Everything else
- Which Perl modules are currently installed?
13-05-2008 1:23 PM
I've been trying out a few scripts, mainly for odd text processing tasks, and I'm finding that sometimes the module I want to use is already there and sometimes it isn't.
Is there a list of what add-ons Plusnet include as standard. Are they just the ones that are packaged with a Perl distribution?
For example I wanted to use XML::Structured. Its now installed to my own "lib" folder, but when I used it it found XML::Parser automatically so I didn't have to install any further bits.
Message 1 of 3
(1,221 Views)
2 REPLIES 2
Re: Which Perl modules are currently installed?
13-05-2008 2:12 PM
Message 2 of 3
(444 Views)
16-05-2008 8:05 AM
Thanks, that worked.
Message 3 of 3
(444 Views)
- Everything else
