Where is PHP Error log?
aenea
Where are PHP error messages written to on the new platform?
5 REPLIES 5
spraxyt
Aspiring Legend
Fixes: 75
Re: Where is PHP Error log?
PHP error messages are suppressed by default since the information exposed increases security risks. If you want to see errors you need to add
php_value display_errors 1
php_value error_reporting 32767
to .htaccess in your code development folder.
David
aenea
Thanks.
Is there any way to write this information to a an error-log file instead of displaying it inline?
spraxyt
Aspiring Legend
Fixes: 75
i haven't tried this but setting the error_log constant should do that. I think .htaccess will need to contain
php_flag log_errors 1
php_value error_log /the/full/path/to/the/error/log_file.log
You could try with display_errors also set initially as a record of what should be in the log.
David
David
aenea
Works a treat!  Smiley
Both in-line display, using display_errors, and writing to a file, using log_errors.
Many thanks.
spraxyt
Aspiring Legend
Fixes: 75
That's good to hear. Thanks for the feedback. Smiley
David
David
