Where Are My Webstats?
- Everything else
- Re: Where Are My Webstats?
11-02-2014 9:31 PM
When I go to 'Website Settings', the 'Advanced Webstats' option has gone. The page just shows 'CGI' and 'Standard Webspace' and clicking through 'Standard Webspace' to 'Website Settings', that page shows CGI twice in the right-hand side menu, with 'Standard Webspace' sandwiched between them (see 1st image).
Clicking on the link to my site at the bottom brings up a pop-up window which - after a few seconds - says can't find the server (see 2nd image).
And I'm sure that my +Net member domain (judgemental.plus.com) used to be listed there as well.
11-02-2014 11:44 PM
For hosted-domain webstats use the domain name in place of the account URL
12-02-2014 1:05 PM
14-02-2014 9:32 PM
It's not much to ask, to be able to view your own site's stats, is it?
15-02-2014 12:18 PM
https://mywebstats.plus.net/plusnet/www.<username>.plus.com
That should present you with a password prompt. Enter your Member Centre username and password and you should be good to go.
15-02-2014 9:03 PM
18-02-2014 10:39 AM
To access this you'll need to click, Website settings, Standard Webspace, then scroll to the bottom of the page where you'll be able to click on your webspace name and then you'll be prompted to enter your logon credentials.
18-02-2014 8:47 PM
- Everything else
