What version of php ?
- Everything else
- What version of php ?
25-06-2015 6:37 PM
I seem to recall that you cant run phpinfo() to find out what version of php is running. Which bears out what Ive seen.
I cant find, using the search exactly what version of php is running. Can anyone enlighten me?
If it's less than 5.5 what is used to encrypt passwords before the introduction of password_hash() ?
Message 1 of 3
(1,878 Views)
2 REPLIES 2
Re: What version of php ?
25-06-2015 7:48 PM
The version of PHP currently on Hostopia ccgi is 5.3.28.
As mentioned in the PHP manual http://php.net/manual/en/faq.passwords.php you could try the third party PHP compatibility library available for PHP 5.3.7 and later. The other option is to use crypt() directly with the blowfish algorithm.
David
Message 2 of 3
(1,213 Views)
20-07-2015 4:42 PM
Quote from: UncleZen I seem to recall that you cant run phpinfo() to find out what version of php is running. Which bears out what Ive seen.
Which is very strange isn't it.. never come across any other hosts that don't allow the use of it
Quote from: UncleZen If it's less than 5.5 what is used to encrypt passwords before the introduction of password_hash() ?
I've always used the sha1 function myself.
Message 3 of 3
(1,213 Views)
