What language?
- Everything else
- Re: What language?
What language?
23-08-2012 11:14 AM
I'm rebuilding my wesite using BlueGriffon & within the user manual it suggests using XHTML5 unless I have a strong knowledge of HTML or I require a specific dialect. As I have niether I will use XHTML5. Is this acceptable for Plusnet?
Message 1 of 3
(831 Views)
2 REPLIES 2
Re: What language?
23-08-2012 7:44 PM
It would be - I think it's down to the visitor's browser rather than the server.
However if you are intending to copy code from your existing site I suggest selecting HTML 4 Transitional. Your existing code complies with that but not HTML 5.
Or are you intending to start from scratch?
David
Message 2 of 3
(248 Views)
Re: What language?
23-08-2012 10:51 PM
Hi Spraxyt, I won't be starting from scratch. As we've discussed, I'll copy into notepad & then copy & paste into BlueGriffon. I'll probably be in touch many times. Best regards, Mick.
Message 3 of 3
(248 Views)
