What is exatly 250MB webspace?
- Everything else
- What is exatly 250MB webspace?
15-09-2007 4:35 PM
Re: What is exatly 250MB webspace?
15-09-2007 5:20 PM
I think you are getting a little mixed up between webspace allowance and bandwidth allowance. Often, hosting providers give you (the hostee) a bandwidth allowance (for arguements sake, say 20GB). If you had a 250MB file on your website, and it was downloaded 80 times (250MB x 80 = 20GB), then your bandwidth allowance will have been exceeded, and your website would not be able to be accessed unless you paid for more bandwidth.
I'm unsure if PlusNet have a bandwidth allowance on their customer hosting space, but I haven't seen any mention of it by others before.
Hope this clears things up for you.
15-09-2007 6:07 PM
15-09-2007 6:16 PM
15-09-2007 6:27 PM
The one argument I have with the PlusNet bandwidth allowance is that it is daily so having large and/or very popular files or images could easily bounce you over the edge before you realise and get the site taken down.
A weekly or even monthly bandwidth allowance would be much better as it would give the owner time to remove or block access to the offending items before tripping the automatic block. That is what I have with 1and1 with the ability to purchase more bandwidth if necessary.
15-09-2007 9:56 PM
If you regularly host large files, you could also set up some mirrors to balance the load a little I suppose.
Do PlusNet currently allow you to purchase more bandwidth, or not due to it being a daily allowance?
15-09-2007 10:06 PM
15-09-2007 10:10 PM
16-09-2007 12:35 PM
The future of web hosting is a topic we are debating internally at the moment. I'm pretty sure it will be the next big focus area once we have Email and Voip stabilised - They are the priorities for the minute.
Ian
16-09-2007 7:04 PM
Quote from: Ianwild This one is already on my wishlist.
Ian
Ian
As someone who is fast running out of webspace I hope you can find a solution even if it means moving to web hosting. I suspect that with hits averaging 15-20 a day I don't come anywhere near my bandwidth limit. What happens if you upload more than the allocated 250mb of web space? As I have said before one of the attractions of Plus Net is the generous web space allowance. Is it really impractical to provide say 500mb as I assume most members don't use their webspace allowance?
David
16-09-2007 9:07 PM
16-09-2007 11:40 PM
17-09-2007 8:48 AM
Quote from: MikeWhitehead If you regularly host large files, you could also set up some mirrors to balance the load a little I suppose.
You cannot purchase extra bandwidth at the moment.
But a couple of solutions that I use are for Videos I place them on you tube, create a playlist and then embed the player on a webpage at +net. It is you tubes bandwidth then instead of yours.
The other is to create a free account at +net which gives you 25 meg of web space and 100 meg of daily data transfer. for the username all I do is just add 1, 2, etc which people do not really notice in the address bar.
So in effect 10 free accounts equal 250 meg webspace and 1 gig of daily transfer.
18-09-2007 2:48 PM
While I appreciate that PlusNet's allowance is rather more generous than others, and they offer CGI and MySQL which some don't, it does seem that offering extra space/bandwidth would be a good way for PlusNet to make some more money as well as satisfying people who need more without having to take their hosting elsewhere. I'm sure as needs grow over time (as they do) it will be something requested more frequently.
I know I've said this before, so it's good this might eventually be offered!
18-09-2007 3:46 PM
With a daily limit you could go off line without notice.
- Everything else
