What happened to my website?
- Everything else
- What happened to my website?
01-01-2008 1:23 PM
As many of you know, I am trying to upload a "new improved" version, and have asked questions in the past couple of days... Since I started this marathon, my original website www.nemosphotography.co.uk is returning the following The page cannot be found and ends HTTP Error 404
I first noticed this on New Years Eve, and when I FTP it showed the root page and htdocs last modified on 30/12/2007. I recently "upgraded" to IE7, but since this has become apparent, and I don`t like the FTP it uses, I have un installed it, and reverted to IE6. I have checked my webstats, and see that on 30 December the site had 712 hits, and on 31 December it had 64 hits.....
My webspace/webstats has been consistently showing the website using 152mb with 98mb free. so I assume it is on the server somewhere particularly as....
I have re-loaded my ORIGINAL website about 1 hour ago, and yet it still shows the 404 page error notice.
I have checked the htdocs folder and confirm that all the files are there
I have checked the index.html file in the htdocs folder, and it works o.k
So why can`t I get into my own website?
Any help appreciated..... thank you
Re: What happened to my website?
01-01-2008 2:46 PM
01-01-2008 3:04 PM
Have you checked the domain name settings? Log in to the Member Centre, click on Domain names, then click Configure. Check it is pointing at the correct location where the index.html can be found, and not, say, a subfolder in htdocs.
01-01-2008 3:05 PM
01-01-2008 4:18 PM
thanks for the replies.... I did add a sub folder to my htdocs, and probably need to go back to domain settings as you mentioned, am away from home at the moment but will look into it when I get back..... watch this space ???;D
01-01-2008 5:21 PM
Hi again
Have been to domain settings, and removed the sub folder, the site files are still in htdocs, but am still getting 404 error
Wot now
01-01-2008 5:33 PM
Try it again later.
Chilly
01-01-2008 8:12 PM
Thanks for the reply chilly..... Have just checked again 20:09, and still not up and running.... will give it another go in the morning and look then..... Wish it said something to that effect on the Domain Name Setting page....
As an aside, I wanted to save having to delete all my website, and then re-load it to htdocs, as it was time consuming, so that means even if it takes 30 minutes to erase, and 30 minutes to upload again, it will still be quicker to try out the new website this way, rather than changing the Domain settings, and waiting 48 hours and the same again to reverse it ! ! !
thanks again for the guidance....
01-01-2008 8:27 PM
01-01-2008 8:34 PM
Shutter plus
nemosphotography.co.uk still 404
01-01-2008 9:07 PM
01-01-2008 9:36 PM
- Everything else
