What DNS should I pick?
- Everything else
- What DNS should I pick?
24-05-2013 10:02 AM
Hi guys,
On my router with autoconfigure (Technicolor TG582n FTTC) the DNS comes as :
If I go to plus.net > Member Centre > Connection settings
The values set are:
Which one should I pick the "automatic set" or the manual ones?
Thanks in advance
{admin}=>:dns server route list
DNS Server Entries:
DNS Server Source Label Metric Intf State Domain
D 212.159.6.10 10 Internet UP *
D 212.159.6.9 10 Internet UP *
{admin}=>
The values set are:
Other settings for manual connection
Primary DNS Server 212.159.13.49
Secondary DNS Server 212.159.13.50
Optional tertiary DNS server 212.159.6.9
Thanks in advance
Message 1 of 5
(1,993 Views)
4 REPLIES 4
Re: What DNS should I pick?
24-05-2013 2:27 PM
Hey there John,
As far as I'm aware, both sets of IP addresses go to the same place anyway.
So in theory, it doesn't matter which addresses you use.
Hope this helps,
Regards,
Matt
Hope this helps,
Regards,
Matt
Message 2 of 5
(331 Views)
24-05-2013 3:11 PM
Above is strange, why would a manual setting be different to the default. Mine is as above:
Primary DNS: 212.159.6.10
Secondary DNS: 212.159.6.9
Perhaps an expert to comment.
Message 3 of 5
(331 Views)
24-05-2013 4:18 PM
Maybe "JohnVi" is a Force9 customer who has upgraded to fibre ?,
as 212.159.13.49 and 212.159.13.50 are the standard settings on F9.
Plusnet FTTC 80/20 IPv4/30, Hurricane Electric 6in4 IPv6/48, Pulse8 landline & calls, SamKnows 600N
Vigor 130 modem, pfSense 2.4.5-p1 router, 5 WAPs, Devolo dLAN 500, Gigaset N300A-IP VoIP DECT
Message 4 of 5
(331 Views)
24-05-2013 4:38 PM
@JohnVi -
I personally wouldn't use any of the Plusnet DNS values, I would recommend choosing any two of the following -
OpenDNS
Google DNS
Norton DNS
As these are all faster and more reliable than the Plusnet DNS
Therefore 208.67.220.220 and 8.8.4.4 would be a good starting point.
OpenDNS
Google DNS
Norton DNS
Message 5 of 5
(331 Views)
- Everything else
