Weird wordpress static hompage/permalink error.
- Everything else
- Weird wordpress static hompage/permalink error.
01-10-2010 10:50 PM
EDIT - OK, I have made the site work correctly, by setting (in the wordpress site settings) the site URL to http://ccgi.collinet.plus.com/~collinet/wordpress (instead of http://ccgi.collinet.plus.com/wordpress). But now of course I get the ~username in all URL's which is just ugly. Any idea how I can get rid of this? Thanks.
(Summary)
With site address in settings set to http://ccgi.collinet.plus.com/~collinet/wordpress everything works, but urls are ugly
With site address in settings set to http://ccgi.collinet.plus.com/wordpress I get the problem with the home page described below - but all URL's omit the ~collinet.
I have just transferred a Church website into wordpress. I have just about managed to get permalinks working to get rid of the /~collinet in the URL. All works fine except for the menu entry to the static homepage.
If I Hover over the "Home" Menu button, http://ccgi.collinet.plus.com/wordpress/ appears in the browser link preview (bottom left of window in Chrome). This is correct.
However, if I click the Home menu button, it goes to http://ccgi.collinet.plus.com/~collinet/wordpress/ - which is wrong and I get a page not found error.
If I click in the Site Name in the header bar, it goes to the correct homepage.
All other page menu entries work correctly
If I change the page used for the home page in wordpress settings, the page named Home now works correctly, and whichever page is set to be the static home page shows the same error.
Anyone any ideas what is going on? (First link above will take you to the site if you want to see for yourself)
EDIT:
- OK, I'm pretty certain it has nothing to do with permalinks (which as far as I can tell, only affects the end of the URL). However, when trying to sort out permalinks, I uploaded the wordpress standard .htaccess file - which is:
(Summary)
EDIT:
Quote # BEGIN WordPress
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /wordpress/
RewriteRule ^index\.php$ -
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . /wordpress/index.php
</IfModule>
# END WordPress
Message 1 of 4
(1,011 Views)
3 REPLIES 3
Re: Weird wordpress static hompage/permalink error.
02-10-2010 12:17 PM
I suggest trying something like the rewrite rules shown in this post.
That post gives background to the origin of ~username in the URL. mod_rewrite is active so there is no need to test for that in the .htaccess file; RewriteEngine On is, of course, needed. I'm uncertain whether RewriteBase should be set to / or /wordpress/.
David
David
David
Message 2 of 4
(212 Views)
02-10-2010 12:33 PM
Message 3 of 4
(212 Views)
02-10-2010 2:00 PM
Thanks all - will look again later.
Message 4 of 4
(212 Views)
- Everything else
