Webstats not generated
- Everything else
- Webstats not generated
19-06-2018 9:44 AM
No sign of Webstats so far this morning (says last generated 18-Jun-2018 04:28 BST (stats for 17/06/18 )).
The PlusNet service status page (accessed via the Member Centre) https://plusnet.servicestatus.net/plusnet/status is blank (no content).
The Comm Site "Service Information" board https://community.plus.net/t5/Service-Information/bd-p/ServiceStatus doesn't give any clues I don't think. That board says (at the top) 'View our current Service Status' which also leads to a blank page.
Post https://community.plus.net/t5/Everything-else/Webstats-data-for-22-01-18/m-p/1510091/highlight/true#... 25/01/18 said
"The script is checked everyday but looked to be completing normally...The next process is where we fell down, we weren't publishing the data. We've now added monitoring of this process to the workflow to reduce chances of this going unnoticed again."
... so it's assumed PN know the Webstats run hasn't generated, and have this in hand?
Project HappyChild - free worksheets, maths, languages, spellings, all sorts - page *here* re linking languages across the world - see also the freeway page
Re: Webstats not generated
19-06-2018 11:17 AM
My stats are also missing. I hope your optimism that Plusnet are aware of the problem is justified.
The Service Status page shows the usual Email-amber state for me. However I think Service Information is the more suitable location for Plusnet to acknowledge the webstats issue.
19-06-2018 11:40 AM
Me too. I noticed webstats were missing earlier and thought I would give PN a while to sort it but still no sign.
19-06-2018 12:01 PM
It's not, this is the first we've heard about it and I've just raised an incident to investigate it (to set expectations its low priority)If they tell me there's an issue then I'll of course update the Service Information Board but we obviously don't and can't post about things we're not aware of.
We do check it every day, not necessarily in the morning but it is checked, it's also perfectly possible that the script can show its completed correctly but not be and our additional checks are of course only designed to "reduce the chances" of it it won't protect against issues we've not encountered before.
19-06-2018 12:24 PM
Thanks for that. However if Webstats haven't generated this would usually indicate that someone would need to start the run manually.
"Investigations" is all well and good, and some sort of explanation of what stopped the run generating/being-published, would be appreciated, in due course, however the priority right now is just to get Webstats run/output, so as not to lose 24h of data if tomorrow's run kicks in without this one having been sorted.
19-06-2018 2:01 PM
Webstats have now arrived here - breathtaking turn of speed.
Many thanks @JonoH for getting things moving so swiftly.
19-06-2018 4:55 PM
Thanks for trying, but I now have just a few entries for 18/06/18 up to 05:16 and nothing after that, so almost the whole day's webstats are still missing,
19-06-2018 9:59 PM
My stats for 18/06.2018 arrived at 13:42. In my case entries through the day as normal.
- Everything else
