Webstats not generated (again on 29th July)?
Tony_W
Mine are still showing those generated early yesterday. Nothing on the service status so far.
Anyone else affected?
Tony
16 REPLIES 16
bobpullen
Fixes: 315
Re: Webstats not generated?
There was a problem this morning Tony. Apologies for not getting something onto the Service Status pages, I'll do that now...
Tony_W
Seems to have happened again today - still showing those generated ~5pm yesterday.
Tony
BenTrimble
Re: Webstats not generated (again on 29th July)?
Service status has been updated.
Penny
Fixes: 8
Quote from: Tony
from service status 28/07
Missing Webstats (62887) - NEW
We are currently investigating a problem affecting the generation of customers' webstats and raw log files.
... Our network engineers are investigating and we will provide a further update once we have more information.
Good to see the stats due 28/07 (for prev day 27/07) did appear (5.15pm~ish here, yesterday) but was surprised that today's (for 28/07) didn't generate at the usual early-morning hour.  Usually whenever a previous run of Webstats has been retrieved on the "due day", the next day's run generates fine.
Have seen today's Service Status update (for which thanks), just wondered if there was any news yet on what might have caused the webstats not to run (automatically) in the early hours of 28/07.
Best regards,
Penny.
Penny Rollo * * * joined Force9 on 17/02/98 * * * with PlusNet from 2000 onwards * * * personal website at pennymidasrollo.plus.com
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
Chris
Legend
Fixes: 169
Yesterday's issue was caused by a permissions error following the work last week to relocate webstats to a different server, this morning's fail appears to be due to an adjustment to the script made yesterday.
Penny
Fixes: 8
okay, and thanks, Chris.  Appreciate the update Smiley
Ben_Brown
Webstats should now have updated for the vast majority of sites, there are about 2000 which are still to be processed. I'm running a clean up script and hope that they will complete in the next hour or so.
Raw logs should be in place for most sites now, there are about 9000 which are currently awaiting processing, which will be kicked off by the clean up script when it's done the webstats processing.
I'm sorry for any disruption this has caused, I've spend the last few weeks moving the webstats data from the old webstats processing servers to our netapp storage, which will make the whole platform more reliable and should reduce instances like this to a minimum. As you can see we've had a few teething issues, but I am confident we're getting to the end of these and should have the service back up and running without any of these sort of hitches.
If anyone's wondering why we're moving away from the webstats servers, it's mainly due to issues with the current hardware which is increasingly causing delays in processing. We have had to make this change quite quickly as the hardware is getting to the end of it's useful life and has recently become much more unreliable.
zubel
Quote from: Ben
... as the hardware is getting to the end of it's useful life and has recently become much more unreliable.
Smiley
B.
Ben_Brown
Not quite that old Smiley
All the webstats and raw logs should be up to date now. Hopefully it will run smoothly tonight, I'll be checking when I get in to the office to make sure.
Ben_Brown
I've had a look at the webstats and it all looks fine today. There are a few more improvements to be made however this is likely to be done after the weekend now.
Penny
Fixes: 8
Quote from: Chris
Just a note to flag up that the Webstats due today (for 03/08) haven't appeared this morning.  Didn't especially want to start a new thread, given that today's issues may still be linked somehow with the server move, but just mentioning as nothing seen on Service Status.
Regards,
Penny.
Ben_Brown
I've been doing some more work on webstats again and I saw that it hadn't run. After some initial investigation I'm not sure of the cause of this but it doesn't seem to be related to the changes I made. We weren't expecting any customer impact so it wasn't announced.
I've just kicked it off and it's got further than the initial checks it failed on last time, and I've just let comms know so I imagine a service status post will be out soon. I'd expect the processing to be complete in two or three hours, however it's the first time we've run the script on this platform so I don't know exactly how long it will take.
Edit: Forgot to add, once the script has run I'll be able to look more in depth to see if I can find the cause.
adamwalker
Fixes: 221
Cheers Ben,
I've just posted this to service status so you should see the update within a couple of minutes.
 Adam Walker
Penny
Fixes: 8
thanks Ben, appreciate the update and background info.
