Webstats missing (10th December)
- Everything else
- Re: Webstats missing (10th December)
10-12-2009 7:26 AM
Still showing those generated yesterday.
Can someone give the box a kick....
Tony
Tony
Message 1 of 6
(1,248 Views)
5 REPLIES 5
10-12-2009 7:34 AM
I just posted this on PUG...
" I hope PNs warning system is kicking in just now. Two successive days!"
Hopefully Chris will spot this.
Message 2 of 6
(455 Views)
10-12-2009 8:59 AM
Indeed the warning system has kicked in and webstats are showing in Opsview. I've raised a problem and a service status will be with you very shortly.
Message 3 of 6
(455 Views)
10-12-2009 9:29 AM
Thanks Chris.
Message 4 of 6
(455 Views)
10-12-2009 9:30 AM
No problems, I'll re-re-reiterate that if webstats appears in monitoring at the very least they need to put a service status out and raise a problem.
Message 5 of 6
(455 Views)
10-12-2009 4:34 PM
Webstats should all be generated now and I've updated the service status.
Message 6 of 6
(455 Views)
- Everything else
