Webstats 26/02/13
- Everything else
- Webstats 26/02/13
Webstats 26/02/13
26-02-2013 12:22 PM
Can somebody start the script and post a service status please...
Tony
Re: Webstats 26/02/13
26-02-2013 12:46 PM
Thanks for notice, I'll get this raised now and a service status posted.
26-02-2013 1:24 PM
26-02-2013 5:26 PM
Sorry for the wait.
27-02-2013 5:06 AM
27-02-2013 10:25 AM
Quote from: Tony As they have not appeared yet, can I assume that these stats are now lost
... well today's have run - though not till half-seven-ish this morning - and yes, there's a gap for yesterday 😕
Did check again around half eleven last night and yesterday's Webstats weren't in, which seemed odd considering the above posts, but figured if I posted late at night no-one involved in sorting out yesterday's stats would be likely to see it.
Hadn't quite anticipated that yesterday's stats just wouldn't appear at all, though. A bit disconcerting.
Regards,
Penny.
Project HappyChild - free worksheets, maths, languages, spellings, all sorts - page *here* re linking languages across the world - see also the freeway page
27-02-2013 11:10 AM
We ran the scripts twice yesterday to generate the stats, unfortunately this failed on both occasions. Yesterdays as you can see have been generated as normal but regrettably Mondays webstats are no longer retrievable.
The <a href="http://usertools.plus.net/status/archive/1361960385.htm">service status</a> has now been closed.
Sorry for any inconvenience caused.
Chris
27-02-2013 1:22 PM
Quote from: chrispurvey We ran the scripts twice yesterday to generate the stats, unfortunately this failed on both occasions.
... don't recall this happening before 😕 does anyone know what caused the scripts to fail twice, Chris?
Losing a whole day's stats doesn't happen very often these days (usually the run gets started or re-started in time) but the run failing twice in succession is something else : /
Some background info as to what happened would be useful, if you're able to provide this.
Thanks,
Penny.
27-02-2013 5:18 PM
I'm still waiting to find out why it failed, it seems as though it was a similar error both times. Once the new following days stats have been generated then we cannot retrieve anything prior to that, so there maybe could be the option of delaying that until they have successfully generated.
As you said it's something that is very rare to do this(twice) and when I have further information I'll share it with you.
27-02-2013 9:20 PM
- Keith
28-02-2013 2:26 AM
Quote from: chrispurvey As you said it's something that is very rare to do this(twice) and when I have further information I'll share it with you.
Thanks Chris, appreciated : )
06-03-2013 7:53 PM
06-03-2013 8:01 PM
