Webstats (13th June) not generated
- Everything else
- Webstats (13th June) not generated
13-06-2013 10:20 AM
No indication on the service status.
Any news as to whether these will be available?
Tony
Re: Webstats (13th June) not generated
13-06-2013 11:53 AM
I've raised a problem(75630) to get the stats generated.
We've posted a service status and I'll update you as soon as I have further information..
13-06-2013 2:15 PM
Quote from: chrispurvey I've raised a problem(75630) to get the stats generated.
Just checked the webstats here and both sets are in (11.56am and 11.57am) but both show virtually no accesses (well, about 0.1% of the usual traffic levels).
Might there be a feeds issue, maybe, or are these figures likely to get overwritten later in the day? It's been a while since I generated Webstats here so I don't recall precisely the mechanics of same-day re-run.
Regards,
Penny.
Project HappyChild - free worksheets, maths, languages, spellings, all sorts - page *here* re linking languages across the world - see also the freeway page
13-06-2013 2:49 PM
Mine are still showing 12th, so I must be further down the list than you - probably less important ;).
I assume that the whole day's stats would still be generated on a re-run. I thought that they only got lost when done on later day, but I could be wrong.
Tony
13-06-2013 4:17 PM
13-06-2013 4:17 PM
Quote from: Tony Mine are still showing 12th
Same here - hope yesterday's logs turn up later today...
13-06-2013 4:35 PM
13-06-2013 4:38 PM
Quote from: Tony Mine are still showing 12th, so I must be further down the list than you - probably less important ;).
lol I thought they just ran everyone's together.
Have to admit to being a bit concerned by the odd stats - like the run got started and then the plug got pulled. A bit difficult to second-guess but I'd expect that you guys will all get full stats later in the day, but because the run was part-done for here, it won't overwrite and I'll be left with the minimal figures currently showing.
I could well be wrong, but from past history I'd think that might be the likely outcome, unless the original problem was a feeds issue, maybe.
... oh, just seen Chris's post - still a bit uncertain that the stats here are going to regenerate, but will check back later.
13-06-2013 6:32 PM
Penny - the script does one person's (or site) at a time until it completes. If it fails at any stage, people at the end of the list do not get their webstats.
Tony
13-06-2013 8:34 PM
Quote from: Tony Penny - the script does one person's (or site) at a time until it completes. If it fails at any stage, people at the end of the list do not get their webstats.
oh, fair enough, didn't entirely realise it was a sequence thing. However, 8.30pm now and no sign of an update. Maybe the fact that it did a partial output earlier, for both sets here, would be enough to stuff up the next run?
Just cleared the cache in case that was relevant, but still showing 11.56/11.57 outputs.
13-06-2013 8:47 PM
Nothing here either. I was going to write in my previous post "I would now be very surprised if we see them at all today. The data generated tomorrow will then obsure the incremental data by overwriting the totals." but refrained from doing so because they might have still been generating.
However, the use of the word 'still' by Chris at 16:35 implies that they had already been running for some time at that stage, so the non-appearance of them over 4 hours later means it is likely that we can kiss them goodbye.
Frustrating as Chris was aware of the situation before noon.
Tony
PS I did suggest some time ago that a minor re-write would allow us to have a button which generated just our own stats to order (perhaps even the button we press to look at the web stats), but the idea was rejected because web stats were considered a low priority, non-core and not worth doing any coding on.
13-06-2013 9:54 PM
I was hoping they would have generated by now.
13-06-2013 10:37 PM
Todays stats have not been generated successfully on the 2nd run of the scripts that were run. We're not 100% certain what caused this to fail, I'll chase this up to find out why.
Yesterdays stats will not now be retrievable unfortunately, but todays should be there for you in the morning.
We've closed the service status off.
Apologies for the inconvenience.
- Everything else
