Webspace permanently broken. Plusnet never respond
- Everything else
- Webspace permanently broken. Plusnet never respond
21-09-2012 8:49 AM
I have a site hosted on my CGI space. www.clanimperium.co.uk
About 90% of the time it doesn't work, instead of getting the home page, you get an index page with a single folder (clanimperium) despite the fact that the whole site is not withing a folder.
When the homepage does work, navigating to the dokuWiki located at http://www.clanimperium.co.uk/wiki results in a URL rewrite to http://www.clanimperium.co.uk/~dcomputers/wiki which, while it works, is undersirable as it exposes my user name.
When I send a ticket to PlusNet, they ignore it. The level of service is farcical and not what I'd expect for a business grade account.
Has anyone got any idea why PlusNet is failing even on the most basic of service provision, and could someone with a clue go and tell them how to do their job?
Re: Webspace permanently broken. Plusnet never respond
21-09-2012 9:37 AM
I'm really sorry that neither of your open tickets have been picked up. Not sure what's happened there but I'm pretty sure we'll not have intentionally been ignoring them. I'll give the Business Support Team a nudge ...
Quote from: dcomputers I have a site hosted on my CGI space. www.clanimperium.co.uk
That's a problem with your additional domain records. They're set up correctly but somebody neglected to flick a switch here and remove the default records. This has been done now so allowing for DNS propagation the problem should be sorted within 24-48 hours.
Quote from: dcomputers When the homepage does work, navigating to the dokuWiki located at http://www.clanimperium.co.uk/wiki results in a URL rewrite to http://www.clanimperium.co.uk/~dcomputers/wiki which, while it works, is undersirable as it exposes my user name.
That's a nuance of the CGI platform and isn't specific to the wiki software you have installed. It would happen with the majority of CGI dependent software like Wordpress, Joomla etc. I think you've been pointed in this direction before, but your best resource of information for this was authored by Gabe on these forums and can be found here.
21-09-2012 9:49 AM
I've seen the forum post you refer to. The only thing in it that appears relevent is the .htaccess file presence, but having checked, I was unable to find any .htaccess files in the folders in my webspace.
21-09-2012 10:47 AM
Gabe
21-09-2012 11:07 AM
http://www.clanimperium.co.uk/wiki is being redirected to http://www.clanimperium/~dcomputers/wiki
What do I need to do to resolve this, and how ill it affect subfolders?
Also why can't PlusNet enact a global fix? It's retarded and certainly doesn't happen on any other host that i've ever used.
21-09-2012 11:45 AM
21-09-2012 11:56 AM
21-09-2012 12:02 PM
@dcomputers
To see .htaccess files, you may need to set your ftp client to show hidden files. Check the home folder and /wiki.
If there are none, then go to reply 11 in that thread. Copy the first 4 lines of code into a txt editor (not the last three) and save as htaccess.txt (just plain text). Upload the file to you home folder and change the file name to .htaccess (remembering the leading dot). That should fix the trailing slash problem and avoid the rewrite. But it looks like the username also got into your settings at installation and probably needs removing.
The problem is partly caused by a global fix to allow legacy code to work with suexec, when the platform was updated in a hurry. The fix should perhaps have been temporary.
Gabe
21-09-2012 12:37 PM
21-09-2012 12:48 PM
21-09-2012 12:55 PM
Customer and Forum Moderator. Windows 10 Firefox 100.0.2 (64-bit (64-bit)
21-09-2012 12:58 PM
Growltiger?
The username is still in the links, so the next thing to do would be to check your docuwiki settings.
Gabe
21-09-2012 1:01 PM
This tends to agree with reports which, when I could access it, others could not.
21-09-2012 1:11 PM
21-09-2012 1:14 PM
Gabe
- Everything else
