Website what website?
graylingirl
I believe I have transfered the required files from my weather station software into htdocs and that an index htm  appears.
Filezilla confirms the transfer but I see only the plusnet advert on my webspace?
Any ideas please? I've just about lost the will to live  Cry
16 REPLIES 16
Strat
Fixes: 565
Re: Website what website?
Remove the Plusnet default index file in htdocs and replace it with your own from your weather station software.
You also may have to do a Ctrl f5  to refresh your browser.
Welcome to the forum by the way Smiley
graylingirl
Hello, Thanks for that but the same result after replacing and refreshing.
I'm sure the world will be riveted by news of the weather in Wales when I'm able to share it.
What to check next please?
spraxyt
Resting Legend
Fixes: 75
Try renaming your index.htm to (say) myindex.htm then browse to http://www. ... /myindex.htm
Does your page now appear or do you get an error?
David
graylingirl
Thank you, Yes I see it, all good but the current date is incorrect as is the weather, (which is sort of important)
I feel we are making progress in making my part of Wales the centre of the meteorlogical  universe. I think I'm ready for the next part of the jigsaw.  Grin
spraxyt
Resting Legend
Fixes: 75
Since that works, do you still have an index.something file in /htdocs? Perhaps index.html which the server might look for before index.htm (can't remember the search order).
With regard to content how is the date set and weather information collected?
David
Chris
Legend
Fixes: 169
I'll go take a look and see if I can spot an error in there.
Chris
Legend
Fixes: 169
In fact, it looks like you've got it working now? You have an index.htm and myindex.htm which both have the same content on and both work correctly.
graylingirl
Ye ha, how clever are you? Many thanks.
Last question.......I hope. Is it necessary to include the index file as part of my webspace address as it does not appear to work without it?
Chris
Legend
Fixes: 169
Most webservers look for an index or default file, that should always be there otherwise anyone visiting your site will have to enter the specific page they want to get to instead of just the main part of your domain.
eg
If you have a page called flowers.html and don't have an index page then I'd need to type www.domain.ext/flowers.html
graylingirl
Oops,
When I sent my last post from work everything was fine the web page was displaying the correct date and time...............however from home  and a few friends who have received links from home are seeing the date as 00:20 on 17th April.
Any ideas please?
Oldjim
Resting Legend
Fixes: 63
Seems OK here
Screen shot taken at 19.07
Strat
Fixes: 565
The time looked fine earlier on today when I viewed the site.
Oldjim
Resting Legend
Fixes: 63
Just checked again
Forecast: Showery early, improving
Conditions at local time 20:50 on 18 April 2012
Strat
Fixes: 565
Forecast: Changeable, mending
Conditions at local time 21:00 on 18 April 2012
What's 'mending' supposed to mean in relation to weather Undecided
Mine is this
Forecast: Mostly cloudy and cooler. Precipitation possible within 12 hours, possibly heavy at times. Windy.
