Website says I'm on VPN and so blocked. But I'm NOT on VPN
- Everything else
- Website says I'm on VPN and so blocked. But I'm NO...
11-03-2022 5:25 PM
A website is blocking me from interacting with it because it thinks I'm using VPN - and I ain't!. I can connect fine via my phone. I have tried to change my ip address by leaving the router off for 3 days, but now I still have the same IP address. Do I have a static address? And if so, how do I make it dynamic and/or change the ip?
Re: Website says I'm on VPN and so blocked. But I'm NOT on VPN
11-03-2022 8:29 PM
I'm really sorry to see you're having issues getting onto a particular site.
What's website address? Also, have you tried contacting whoever owns it?
11-03-2022 8:42 PM
I have contacted the website - and got no reply. The website is newtumbl.com. Googling indicates that other people have had similar problems on a number of sites, including Netflix. I was hoping a simple change of ip would fix it
13-03-2022 6:34 PM
Thanks for getting back to me @Bacchanalia
Send me a private message with your account username and I'll be happy to take a closer look ![]()
- Everything else
