Website removed due to excessive bandwidth use
Geoff_E
Once again my website has been removed because of excessive bandwidth use. This seems to happen about once a year and I'm at a loss to understand what's going on.
Posting here in hopes someone from support can get it back online.
Thanks,
Geoff
6 REPLIES 6
Tina11192
Fixes: 18
Re: Website removed due to excessive bandwidth use
Hi @Geoff_E thank you for taking the time to contact us. I have raised this with our NetOps team, please follow this link for a more detailed response: https://www.plus.net/wizard/?p=view_question&id=245948845
Please let me know if there's anything else we may look into for you
Cri Ignatti
Fixes: 241
Do you have web stats enabled in the site? Inspection of that might give some clue as to what / who has burnt your bandwidth.
If it is an indexing bot, consider configuring a robot.txt file to exclude images etc.
Geoff_E
Website back online. Many thanks.
I do not have webstats enabled so far as I'm aware.
My suspicion was a bot - this seems to happen at pretty precisely six or twelve month intervals. I'll look into sorting out a robots.txt file. I have a lot of pdfs on the site so if a bot is downloading them all to index them I guess that would do it.
Thanks again,
Geoff
Fixes: 241
This is an option under manage my webspace.
quelquod
I used to get this for the same reason - a large pdf was repeatedly being downloaded from time to time. A bot file seems to have sorted it.
Democracy - 3 wolves and a lamb voting about what to have for lunch!
Geoff_E
I've put in a robots.txt file that disallows all the pdfs. Hopefully that will solve the problem.
Thanks for your help!
Geoff
