Website has exceeded bandwidth for 4th time.
g3ucq
As the title but how do I prevent this from happening again?  Can I add some code?
If there is an answer please give me chapter and verse.
Thank you in adavcne.
14 REPLIES 14
spraxyt
Aspiring Legend
Fixes: 75
Re: Website has exceeded bandwidth for 4th time.
Do you host some high resolution images (or other large large size files) on your website that might attract lots of visitors (eg via search engine links)? Or could other websites be hot linking to images on your site because they are attractive?
The first step is to find out which parts of your website are associated with the high levels of usage, then you are in a position to work out how to deal with it.
David
g3ucq
Thank you for your reply. I think now that it is hot linking that is likely to be causing the problem as I have a number of images on my website which are rather special.  (www.soqotra.info for those interested.) So I am looking into ways of preventing that.
avatastic
Is this http://www.htaccesstools.com/hotlink-protection/ of any use?
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
g3ucq
Thank you avatastic.  I found that site, created the .htaccess file and uploaded it to my website.  Now I cannot see any images! Cry
avatastic
Did you add both http://www.johnfarrar.plus.com/ and www.soqotra.info as allowed domains?
TORPC
http://www.soqotra.info/ is now redirecting to http://www.johnfarrar.plus.com/
Is this supposed to happen ?Huh
g3ucq
Yes that is OK.
Avatastic. No I had not added both URLs but I have now done that and the images are back again.  Thank you very much for the hint.
It is still possible to save an image and copy the location of an image so has hot linking prevention really been added?
Thanks again
dick:quote
TORPC
I can confirm that the images are back here also Wink
g3ucq
Hi
Thanks.  I just used a hotlink checker and it seems that prevention is running OK.
Do you guys agree?
Oldjim
Fixes: 63
http://www.johnfarrar.plus.com/wpimages/ec9c.jpg is blocked
TORPC
Testing image
http://www.johnfarrar.plus.com/wpimages/82a3.jpg looks blocked to me Wink
g3ucq
Excellent.  Thank you for your time and help.
Have a good weekend.
forsterbalcke
I have the same problem.
My website has been Archived for exceeding bandwidth - never happened before!
www.holywellhousepublishing.co.uk
What is my band width allowance?
Why am I so popular all of a sudden!
How do I find out if pages are being hot linked?
Or is there another explanation?
And why does Plusnet cut you off without offering any advice or help in solving the problem?
Bill
[Moderator's note by Dick(Strat) All caps edited.
bobpullen
Fixes: 290
Please see my reply to your post here.
