Website builder
- Everything else
- Website builder
Website builder
02-08-2007 11:11 AM
Re: Website builder
02-08-2007 11:16 AM
We're currently reviewing options for a replacement, but in the meantime - take a look here if you're looking to build your own website :-
http://www.hit-counter-download.com/free-website-builder.html
Re: Website builder
02-08-2007 10:01 PM
I've tried the Composer suggestion, downloaded as part of Netscape - and free too!
Although I made a page quite easily, and have validated it successfully, I can't upload it to my PlusNet webspace?
I don't want to divert this thread but 'mikegm' may find himself in a similar situation soon, so can somebody tell me how to replace my old WebBuilder page with my updated Composer page?
Thanks,
Stewart
Re: Website builder
03-08-2007 4:24 PM
If thisis the case then in your browser address window enter ftp://ftp.plus.net
You will be presented with a box requesting your username and password.
Complete these and you will then find a window with your web space in it.
Navigate to the folder called htdocs and you should see your old files.
Delete these and then drag and drop the newly created ones into the htdocs folder.
You could also download a FTP client such as Cute ftp and use one of those if you wanted instead of the method above.
Hope that helps.
Re: Website builder
03-08-2007 5:27 PM
Re: Website builder
04-08-2007 10:26 PM
Do you have to wait for some overnight change for them to be uploaded?
Re: Website builder
04-08-2007 10:45 PM
e.g. file:///D:/Documents%20and%20Settings/Stewart%20Borland.HOMESYSTEM/My%20Documents/My%20Pictures/Cars/avatar.jpg
Which will clearly work on your own PC but that path is completely wrong for the web server.
Where have you put the images in relation to the home page. If they are in an images folder, so the above is actually images/Cars/avatar.jpg, then the above line should only contain "images/Cars/avatar.jpg".
All files and links need to be referenced relative to where the .html page is.
This is often the problem with some web packages that assume you will run the website where you are developing it (i.e. on yur own PC) rather than on a separate web server and they often then get the path to the images wrong unless you know what you are doing and can specify it relative to the html file.
Re: Website builder
05-08-2007 4:00 PM
Many thanks to all.
Re: Website builder
05-08-2007 4:39 PM
To avoid the confusion I always make my file names one word. You can if need be make them look like file_name with the underscore if it helps clarity to have two or more words for the file name.
Another thing to do is to only ever use lowercase for all files and there extensions. I have in the past spent ages trying to figure out why a file couldn't be seen to eventualy find a stray capital letter and I have called it from all lower case.
So it is a good habit to get into to make everything lower case.
Keep at it and you will get there.
Re: Website builder
05-08-2007 8:20 PM
My picture links now read like this -
src="file:///ftp://stewarta13wsb@ftp.plus.net/htdocs/DSCF0007.JPG"
but although they no longer show on my PC, they don't show on line either, which begs another question - the background has the original link (like the one you quoted, starting with the D drive, and it works) why is that when the other photos don't, and what's wrong with the new links?
Sorry to be a pain,
Stewart
just saw the other post, is it upper/lower case that's doing it now?
Re: Website builder
05-08-2007 9:31 PM
It should look like this assuming that the image is in the same folder as the index file. <IMG SRC="trip5.jpg" WIDTH="384" HEIGHT="288">
The above is a copy of a link from one of my web pages. If you don't know the width and hight then leave that out alltogether and just use <IMG SRC="trip5.jpg"> with of course the name for your own image.
If you are unsure about html commands then this is my bible http://www.idocs.com/ where you can find out how to do just about anything with html code.
Edit:- added link to idocs site.
Re: Website builder
05-08-2007 9:54 PM
And that's without Website Builder... if I can do it, anybody can.
So use your PlusNet space with Composer via Netscape and the whole exercise is free and almost painless!!
www.stewarta13wsb.plus.com if you want a look at the work in progress.
EDIT: one snag - looks fine on my screen @ 1024x768 but a hideous mess at 800x600 - how do you allow for that?
Re: Website builder
05-08-2007 10:02 PM
Loch Leven looks magnificent
Re: Website builder
06-08-2007 10:39 PM
Re: Website builder
06-08-2007 11:19 PM
Next you need to learn about reducing the size (in bytes) of your images as some are too big and take a while to load.
