Website blocked
- Everything else
- Website blocked
- « Previous
- 1
- 2
- Next »
Re: Website blocked
01-02-2020 8:08 AM
Added to my hosts file (eventually! Win10 hates users being in charge of their own PC) but still doesn't work
Re: Website blocked
01-02-2020 9:02 AM
Thanks for the update, I've just tested this on my home connection and I'm unable to load the site and I've got a static IP, the IP of the site 52.168.148.33 works fine though. @Kelly let me know if you need me to do any testing too.
Re: Website blocked
07-02-2020 10:37 PM
Any further testing you want me to try?
Re: Website blocked
08-02-2020 1:01 AM
The site loads for me at home where I have a static IP in the range 212.159.x.x. However nslookup results in
C:\nslookup wiki.ispace.org 212.159.6.10
Server: cdns02.plus.net
Address: 212.159.6.10
Non-authoritative answer:
Address: 72.52.178.23
Aliases: wiki.ispace.org
which is a makedly different IP from the 52.168.148.33 mentioned in message #13 https://community.plus.net/t5/Everything-else/Website-blocked/m-p/1704363#M23187
Re: Website blocked
08-02-2020 4:15 PM
So does that imply a DNS issue?
Re: Website blocked
11-02-2020 11:32 AM
Hey @chrisboote,
To be honest I'm not sure what the next steps with this would be, it seems @Kelly was working on something behind the scenes or may have been investigating something. Might be worth awaiting his response.
Thanks.
Re: Website blocked
11-02-2020 10:02 PM
I can't visit the page either, it's not blocked though.
Looks like it might be something todo with their DNS server, their aname and nameserver records seem to be fudged.
Re: Website blocked
13-02-2020 3:45 PM
Seems like I managed to delete my reply when I deleted what I thought was a double post
I asked one of our engineers to have a look and they think there is something wrong with their DNS records:
Looks to be a DNSSEC configuration problem with the authoritive DNS server for this domain. This means that our servers aren’t able to validate the chain of security from the authoritive servers upwards. At a guess this is intermittent due to older cached records which may well be the problem as some may be correct, and some not.
Testing it from one of our cachedns servers fails locally and against the nameservers Jon mentions, giving a SERVFAIL response:
root@cachedns07:~# dig wiki.lspace.org +cmd
; <<>> DiG 9.9.5-9+deb8u18-Debian <<>> wiki.lspace.org +cmd
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 74
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
root@cachedns07:~# dig wiki.lspace.org +nocmd @dns1.registrar-servers.com
; <<>> DiG 9.9.5-9+deb8u18-Debian <<>> wiki.lspace.org +nocmd @dns1.registrar-servers.com
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 20411
;; flags: qr rd; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
Running the check with an additional flag to disable DNSSEC checking resolves locally, but still fails against the others:
root@cachedns07:~# dig wiki.lspace.org +nocmd +cd @dns1.registrar-servers.com
; <<>> DiG 9.9.5-9+deb8u18-Debian <<>> wiki.lspace.org +nocmd +cd @dns1.registrar-servers.com
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 65506
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 36985
;; flags: qr rd ra cd; QUERY: 1, ANSWER: 2, AUTHORITY: 2, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;wiki.lspace.org. IN A
;; ANSWER SECTION:
wiki.lspace.org. 1522 IN CNAME wiki.osiris-web.com.
wiki.osiris-web.com. 1547 IN A 52.168.148.33
;; AUTHORITY SECTION:
osiris-web.com. 1548 IN NS dns1.registrar-servers.com.
osiris-web.com. 1548 IN NS dns2.registrar-servers.com.
Also confirmed this against the advertised IP’s for our DNS servers to make sure, with the same response received:
root@server52752:~# dig wiki.lspace.org +nocmd +cd @212.159.13.49
; <<>> DiG 9.8.4-rpz2+rl005.12-P1 <<>> wiki.lspace.org +nocmd +cd @212.159.13.49
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 19297
;; flags: qr rd ra cd; QUERY: 1, ANSWER: 2, AUTHORITY: 2, ADDITIONAL: 0
;; ANSWER SECTION:
wiki.lspace.org. 1460 IN CNAME wiki.osiris-web.com.
wiki.osiris-web.com. 1485 IN A 52.168.148.33
osiris-web.com. 1486 IN NS dns1.registrar-servers.com.
osiris-web.com. 1486 IN NS dns2.registrar-servers.com.
Broadband Service Manager
Re: Website blocked
15-02-2020 12:14 AM
But I can open it when I'm accessing with 4G, or from work
Only fails when opening it from PlusNet broadband
Re: Website blocked
18-02-2020 8:14 PM
Anything I can do? Or pass on to site owners?
Re: Website blocked
24-02-2020 6:10 PM
Is there nothing to be done to resolve this?
Re: Website blocked
24-02-2020 6:20 PM
@Mav wrote:Just checked the site using my PN static IP and no luck with similar message to the OP.
Just checked again and the site appears to be working normally now for me.
Forum Moderator and Customer
Re: Website blocked
24-02-2020 6:42 PM
Not for me
Re: Website blocked
06-03-2020 9:35 AM
Have you tried reaching out to the site owners to see if they've something wrong on our side?
Re: Website blocked
06-03-2020 9:36 AM
@chrisboote Another work around would be to enable safeguard and then turn off the filters (unless you want them on). That means you'll be assigned a different set of DNS servers which might not see the issue? (If this works, I'd be interested to see!)
- « Previous
- 1
- 2
- Next »
