Website blocked
chrisboote
Re: Website blocked
Added to my hosts file (eventually! Win10 hates users being in charge of their own PC) but still doesn't work
Fixes: 845
Re: Website blocked
Thanks for the update, I've just tested this on my home connection and I'm unable to load the site and I've got a static IP, the IP of the site 52.168.148.33 works fine though. @Kelly let me know if you need me to do any testing too. Smiley
chrisboote
Re: Website blocked
Any further testing you want me to try?
Fixes: 73
Re: Website blocked
The site loads for me at home where I have a static IP in the range 212.159.x.x. However nslookup results in
C:\nslookup wiki.ispace.org 212.159.6.10
Server:  cdns02.plus.net
Address:  212.159.6.10
Non-authoritative answer:
Address:  72.52.178.23
Aliases:  wiki.ispace.org
which is a makedly different IP from the  52.168.148.33 mentioned in message #13 https://community.plus.net/t5/Everything-else/Website-blocked/m-p/1704363#M23187
David
chrisboote
Re: Website blocked
So does that imply a DNS issue?
Fixes: 63
Re: Website blocked
Hey @chrisboote,
To be honest I'm not sure what the next steps with this would be, it seems @Kelly was working on something behind the scenes or may have been investigating something. Might be worth awaiting his response.
Thanks.
 Maddy S
blu3andp1p
Re: Website blocked
I can't visit the page either, it's not blocked though.
Looks like it might be something todo with their DNS server, their aname and nameserver records seem to be fudged.
https://dnsmap.io/#A/www.wiki.lspace.org
Fixes: 7
Re: Website blocked
Seems like I managed to delete my reply when I deleted what I thought was a double post Cheesy
I asked one of our engineers to have a look and they think there is something wrong with their DNS records:
Looks to be a DNSSEC configuration problem with the authoritive DNS server for this domain. This means that our servers aren’t able to validate the chain of security from the authoritive servers upwards. At a guess this is intermittent due to older cached records which may well be the problem as some may be correct, and some not.
Testing it from one of our cachedns servers fails locally and against the nameservers Jon mentions, giving a SERVFAIL response:
root@cachedns07:~# dig wiki.lspace.org +cmd
; <<>> DiG 9.9.5-9+deb8u18-Debian <<>> wiki.lspace.org +cmd
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 74
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
root@cachedns07:~# dig wiki.lspace.org +nocmd @dns1.registrar-servers.com
; <<>> DiG 9.9.5-9+deb8u18-Debian <<>> wiki.lspace.org +nocmd @dns1.registrar-servers.com
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 20411
;; flags: qr rd; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
Running the check with an additional flag to disable DNSSEC checking resolves locally, but still fails against the others:
root@cachedns07:~# dig wiki.lspace.org +nocmd +cd @dns1.registrar-servers.com
; <<>> DiG 9.9.5-9+deb8u18-Debian <<>> wiki.lspace.org +nocmd +cd @dns1.registrar-servers.com
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 65506
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 36985
;; flags: qr rd ra cd; QUERY: 1, ANSWER: 2, AUTHORITY: 2, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;wiki.lspace.org.              IN          A
;; ANSWER SECTION:
wiki.lspace.org.  1522     IN          CNAME wiki.osiris-web.com.
wiki.osiris-web.com.       1547     IN          A              52.168.148.33
;; AUTHORITY SECTION:
osiris-web.com.               1548     IN          NS              dns1.registrar-servers.com.
osiris-web.com.               1548     IN          NS              dns2.registrar-servers.com.
Also confirmed this against the advertised IP’s for our DNS servers to make sure, with the same response received:
root@server52752:~# dig wiki.lspace.org +nocmd +cd @212.159.13.49
; <<>> DiG 9.8.4-rpz2+rl005.12-P1 <<>> wiki.lspace.org +nocmd +cd @212.159.13.49
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 19297
;; flags: qr rd ra cd; QUERY: 1, ANSWER: 2, AUTHORITY: 2, ADDITIONAL: 0
;; ANSWER SECTION:
wiki.lspace.org.  1460     IN          CNAME wiki.osiris-web.com.
wiki.osiris-web.com.       1485     IN          A              52.168.148.33
osiris-web.com.               1486     IN          NS              dns1.registrar-servers.com.
osiris-web.com.               1486     IN          NS              dns2.registrar-servers.com.
Kelly Dorset
Broadband Service Manager
chrisboote
Re: Website blocked
But I can open it when I'm accessing with 4G, or from work
Only fails when opening it from PlusNet broadband
chrisboote
Re: Website blocked
Anything I can do? Or pass on to site owners?
