Website blocked
chrisboote
Website blocked
https://wiki.lspace.org/ is blocked from my plusnet internet connection
I can open it fine using 4G, or from work, but not at home
Not been able to access chat support for months (just says 'not available at this time')
How do I get this unblocked?
29 REPLIES 29
idonno
Champion
Fixes: 6
Re: Website blocked
Live Chat? .... have a read
Ever helpful. Grin Sure, I’d love to help you out. Now which way did you come in?
RandallFlagg
Fixes: 75
Re: Website blocked
Hi @chrisboote
Thanks for getting in touch.
When this website is blocked, what error message is displayed?
This sounds like it may be being blocked by Safeguard, which you can amend to allow the site here
Best wishes
Dave
chrisboote
Re: Website blocked
Hello Randall
I'm not using safeguard, and ther people I know with PlusNet get the same error - implying it's blocked by PlusNet globally
I can access it without issue from work or using 4G on my 'phone
The error is "Hmm we seem to be having trouble finding that site. We can't connect to the server at wiki.lspace.org"
RandallFlagg
Fixes: 75
Re: Website blocked
Hi @chrisboote
Thanks for the clarity.
Could you switch your router off this evening before you go to sleep and turn it back on again tomorrow morning?
This sounds like it could be an IP range issue - turning the router off overnight (or for over four hours if it's convenient) should force the router to refresh the IP address and allow access.
If that doesn't help, let us know and we'll look at adding a static IP to see if that resolves the issue.
Dave
Mav
Fixes: 515
Re: Website blocked
@chrisboote
@RandallFlagg
Just checked the site using my PN static IP and no luck with similar message to the OP.
No problems accessing from mobile which is EE.
Forum Moderator and Customer
RandallFlagg
Fixes: 75
Re: Website blocked
Thanks for checking this, @Mav
This is an odd one as I can access the site perfectly from this side.
As a fellow Discworld fan, this pains me a great deal - I'll check this from my home connection this evening to see if I get the same issue.
@christboote - could you please attempt the IP refresh overnight/this evening and if this persists we'll raise this with our network team?
Dave
Mook
Seasoned Champion
Fixes: 9
Re: Website blocked
For what it is worth, this site works for me. @RandallFlagg @Mav @chrisboote
Legend
Fixes: 255
Re: Website blocked
Doesn't work for me - IP is 51.6.246.xx
Fixes: 395
Re: Website blocked
@RandallFlagg Dave, most odd!
Using nslookup, wiki.lspace.org doesnt resolve via either the standard ( 212.159.13.49 ) or alternate ( 212.159.6.9 ) PlusNet DNS servers. It DOES resolve from the Safeguard ( 213.120.234.42 ) one though. It also resolves fine via OpenDNS.
Very strange ...
chrisboote
Re: Website blocked
I'll do the IP refresh tonight
Chris
Kelly
Fixes: 9
Re: Website blocked
I just tested this from my home Plusnet connection and it works.  Will take a closer look tomorrow when I'm in the office.
Kelly Dorset
Ex-Broadband Service Manager
Fixes: 1,600
Re: Website blocked
Hi Chris, as a workaround you could try accessing the website by going to 52.168.148.33 although it won't be a https secure way of browsing. Let us know how it goes.
Kelly
Fixes: 9
Re: Website blocked
A better workaround would be to add this to your hosts file.  Then it would be ssl.
https://www.howtogeek.com/howto/27350/beginner-geek-how-to-edit-your-hosts-file/
Bear in mind though that if their IP address changed, this would stop working and you'd need to update the entry to the new IP.
Mean while, we can see something odd is happening here and we're taking a look.  It migh be something wrong with the hosts DNS configuration, rather than anything under our control, but we should ensure there isn't something odd happening in our infrastructure.
Kelly Dorset
chrisboote
Re: Website blocked
Using the IP address works fine
I turned my router off for ~6 hours last night as requested -  no effect
I'll look at the hosts file this evening
Thanks all
